Fn + M (in the frame between Fn and the Right CTRL)
ahijos
[color=rgba(0, 0, 0, 0.87)]I have a Vigor 80 keyboard as I press the Fn key with a dragon plus the one between them, and the right CTRL - M in the frame is the keyboard is highlighted in white, and when you press a key, it changes color and then nothing happens.[/color]
[color=rgba(0, 0, 0, 0.87)]What is this Fn + M function in the frame?[/color]
I already know this macro programming mode.
Fn + M - white keyboard or macro programming mode
we choose the key that turns yellow
then choose the sequence of keys to be in the macro and end with the M key
in the frame
it turns red
We leave the Fn + M programming mode
Selecting the macro - M in the frame plus the preset key
It is a pity that this is not in the instructions.
PS: Note the programming of such keys as one, two etc. which are used for
something, for example to change the profile, because deleting is possible only
by pressing for 5 seconds.Fn - R means reset the keyboard and we lose all settings and entries.
