Forum UEFI Shell Flash tool [V1.12] for MSI boards!
Active member
Administrator
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
How to use:
Download the tool from the link:
and extract all contents over the USB key, [FAT32 formatted]
copy/extract the folder structure As Is to the USB key.
Do not omit the folders and sub-folders.
I.e: USB key root structure should looks:
then also add/copy/extract desire MSI UEFI BIOS that you want flash,
on USB key main/root (\) folder.
for example i want to flash a E7A34AMS.M90 BIOS,
and copied the BIOS file on USB key main/root folder/directory:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
Then boot from USB key,
in UEFI Mode,
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:
I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
You can attach the link to your top message in this discussion theme. :) Thank you Again !
Here is the link to video:
[youtube]
Active member
Administrator
Yes, it will works fine for that too.
Active member
Administrator
It's one of my apps. that's part of the tool.
Active member
Administrator
Update:
Flash tool been updated ver. V1.11 with many new features and add support for many new MSI boards.
Active member
Administrator
Update:
Flash tool been updated ver. V1.12,
add enhanced support and detection for MEG Z490 GODLIKE for ME FW Update purpose,
and implement various of new functions.
Simulations shots:
