- Nov 20, 2003
Important:
Do NOT use it on a MSI AMD boards from 3xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
How to use:
Download the tool from the link:
Forum UEFI Shell Flash tool [V1.19]
or use special version for Blind Flashing:
For Blind Flashing only: Forum UEFI Shell Flash tool [V1.19]
[prepare the USB key for flashing,[see details below how to prepare it] then shutdown the PC,
General instructions for USB key preparation within Windows for both versions:
and extract all contents over the USB key, [FAT32 formatted]
copy/extract the folder structure As Is to the USB key.
Do not omit the folders and sub-folders.
I.e: USB key root structure should looks:
then also add/copy/extract desire MSI UEFI BIOS that you want flash,
on USB key main/root (\) folder.
for example i want to flash a E7A34AMS.M90 BIOS,
and copied the BIOS file on USB key main/root folder/directory:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
Then boot from USB key,
in UEFI Mode,
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
Important:
MEG Z490 UNIFY
MEG Z490I UNIFY
Z490-A PRO
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
How to use:
in UEFI Mode,
UEFI USB your drive
efmled date=1563998092 said:I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
efmled date=1563998092 said:You can attach the link to your top message in this discussion theme.Thank you Again !
Here is the link to video:
[youtube]
