Forum UEFI Shell Flash tool [V1.19] for MSI boards! ✔
escape75
Don't have info about this unit, check it with MSI here:
>>How to contact MSI.<<
That's strange,- but maybe it's because a Canadian model.
In any case they seem to have the same ones in USA,- same BIOS:
Also in Europe, but they are model 10SI-1051MYS.
Hmm, oh well thanks anyway!
escape75
I think based on that it's "safe" to say it's really an H410M PRO board, ignore the green PCH heatsink, it didn't come with any heatsink :)
Administrator
On a paper that's totally different model.
If you gonna cross-flash it, you must be prepared in a case of bricking and non boot, and for HW BIOS chip re-flashing with SPI Programmer.
escape75
Ok, well I do have an SPI programmer and a backup done with the Intel FPT tool :)
I don't have a lot of SPI programming experience, and I would need to locate the BIOS chip.
I compared my OEM model with Retail and the pictures (aside from heatsink) look identical,
but I do understand that cross-flashing might not always produce the expected results ...
I guess I'll have to think whether it's worth it, and I'm not sure what I would be gaining by going to Retail BIOS :)
PS: That system included the GTX 1650 Super and also a custom OEM BIOS and I've had issues with black screen flicker,
I re-flashed that with the Retail version (hex compare showed only few differenced) and there's been no issues since!
Thanks again!
dstraws161902f8
Where do I send $$$?
A Big Thank You!, to Swet for this Flash tool. I struggled for hours, basically a day, resetting CMOS, jumpering the battery pins, removing memory, pci cards, connecting various monitors, all to no success, M-Flash would not display, It would enter into a black screen, everything was running. but I could not flash a new BIOS on the X470 Gaming Plus Max.
After hours of googling, I finally ran across the post about the Flash Tool, created a new USB, loaded it up from instructions and within 20 minutes I am typing this post.
To be honest, I have a replacement Gigabyte board in my Amazon cart, because I was over MSI.
Thanks Again, MSI owes you.
lemosneth157802da
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
How to use:
Download the tool from the link:
or use special version for Blind Flashing:
For Blind Flashing only: Forum UEFI Shell Flash tool [V1.19]
[prepare the USB key for flashing,[see details below how to prepare it] then shutdown the PC,
General instructions for USB key preparation within Windows for both versions:
and extract all contents over the USB key, [FAT32 formatted]
copy/extract the folder structure As Is to the USB key.
Do not omit the folders and sub-folders.
I.e: USB key root structure should looks:
then also add/copy/extract desire MSI UEFI BIOS that you want flash,
on USB key main/root (\) folder.
for example i want to flash a E7A34AMS.M90 BIOS,
and copied the BIOS file on USB key main/root folder/directory:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
Then boot from USB key,
in UEFI Mode,
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
Can I use this to roll back an A320M-A PRO MAX update???
f2pdange155d02d9
Can I use this with my MSI PRO Z690-A DDR4? Having issues using M-Flash. It'll reboot and say entering flash mode then hand on a black screen.
Pro
The MSI PRO Z690-A DDR4 has a Flash BIOS Button, so just use that to update the BIOS:
1. Download the latest BIOS file for your board and extract it.
2. Rename the BIOS file to MSI.ROM, and save it to the root of your USB flash drive / USB stick (not in a subfolder). FAT32 formatting is a must for the USB flash drive.
3. Plug the USB flash drive that contains the MSI.ROM file into the Flash BIOS Port on the rear I/O panel.
4. With the PC off, press the Flash BIOS Button, and the LED starts flashing for about 5-7 minutes.
The Flash BIOS Button method is quite picky about the USB stick. In fact, the old and cheap USB sticks with small capacity seem to work the best for that method, read here or here. You need to find a USB stick / pen drive that the board likes. It needs to flash for about 5-7 minutes and then it will reboot. Anything drastically different (under a minute of flashing, or over 10 minutes of flashing) and the flashing didn't work, so you can abort and try with the next USB stick.
If the problem persists with the new BIOS, then make a new thread about it and include all your hardware. The clue is not in the BIOS version then, but in your hardware.
escape75
It's because they are build with a different security feature and you are trying to do a cross-flash.
Like here:
Yeah, I'm wondering if converting to an H510M PRO would be a good choice as it's had quite a few BIOS updates compared to mine:
This is the release for my system, as you can see it's still the original BIOS, unless you have an update maybe?
I'm trying to fix an issue with PCIE power saving as best as I can tell:
I have a backup done with Intel FPT but haven't tried flashing the backup yet ...
How hard is the procedure to convert OEM to Retail and I'm guessing Windows would need re-activation, etc.
mjones61
I have a PowerSpec G223 with an MSI B360-A Pro (MS-7B22) that has a custom BiOS file. Can I use this toll to write the latest MSI firmware?
Thanks for the awesome tool,
I accidentally flashed the wrong bios to my MPG Z390M Gaming Edge AC but the mobo still worked. ( 7B17vAC2(Beta version)). Should have used this -> 7B50v1C2(Beta version)
After formatting and installing win 11 everything was working great (with wrong BIOS) but I got a warning from MS defender to enable memory integrity. After changing that option the board boots but I get no display and sometimes the Debug LED is fixed on RAM.
My question is in relation to the blind flashing, the last settings I had on bios were to enable secure boot will the blind flashing not work in this instance? I think the BIOS is def an issue and I want to try the blind flashing option before going over to something like the CH341A.
Also the link provided for the blind flashing utility seems to be broken do you have another link for it?
Lastly any idea where the BIOS Chip is located on the Z390M Gaming Edge AC?
Pro
Should be this one, most likely a Winbond 25Q128JV, 128 MBit (16 MB), working with 3.3V.
You will have to remove the chipset heatsink (two screws from the rear of the board) if you want to clamp onto the chip. Or you may be able to use the JSPI1 header.
