Forum UEFI Shell Flash tool [V1.19] for MSI boards! ✔
escape75
Just a quick question .. I'm thinking about flashing my Infinite 10SA-1075CA (MSI OEM) with H410M PRO (MSI RETAIL) bios ...
I have found the Intel FPT 14.5.x tool that backed up my BIOS and created a 16MB file without any errors.
Am I correctly assuming I can restore this backup anytime with the Intel FPT tool ?
Thanks!
Xtreme1986
That's because your current OEM BIOS and retail BIOS that you trying to flash,
are build via different security mechanisms and your current BIOS do not allow flashing to non - secure/signed BIOS files.
You have to use the correct BIOS file for your board, check it with your OEM vendor.
Or are you intentionally trying to do a cross-flash to retail BIOS?
Hi Svet thanks for helping I am intentionally trying to cross-flash to retail BIOS.
Administrator
If the computer can boot is in working condition to reflash, yes.
That could be risky and brick your board, but if want to try it anyway at own risk PM me.
nicola156b02de
Thank you Svet !
I have updated my B350 TOMAHAWK with the last 7A34v1Q7 (Beta version of 2022-07-15) and it was the bigining of the end !
Impossible to downgrade with the official Flash method by MSI.
But your little script saves my life (or rather my motherboard)
It work perfectly and it s very simple to use. (even with the B350 chipset)
Now i am on the last stable version : 7A34v1M ( 2019-01-30 )
On the other hand, the letters 'a' and 'q' are not a good choice.
I'm french guy with an azerty keyboard ( 'a' => 'q' and 'q' = 'a' )
Thank you again.
Administrator
Super. Welcome, thanks for the feedback :emot-tip-wink:
dandroid2115b202ea
Hi. i have a msi prebuit pc (modified now) with the msi z390-a pro motherboard, and that has the prebuilt bios installed. so overcklock does not work that well on my i7-9700kf. and i have no bios updates (last was in 2019) eb913ims.h30 is the bios. is it possible to flash the retail bios update to this?
Any update? i tried the tool but it wont work it says this. I have a similiar pre built except i swapped out the 2070 in it for a 3090 and new psu. I want to use resizable bar but i need to update to latest bios but it only wants the weird pre built pc bios instead
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
hi, what's your current BIOS version? can you share a screenshot of msinfo32?
- press windows key + r
- type msinfo32
dandroid2115b202ea
im trying to also. my mobo is a z390 mortar but its from a pre built pc and has these weird bios. im just trying to get resizable bar lol
Administrator
Malechai
Hi there, I read thru this thread and I'm not entirely clear on a few things and was hoping I could ask a few questions.
I'm new to MSI and pre-built PCs and recently purchased an MSI Codex R 12th desktop and as per the BIOS, the MB and BIOS Ver are listed as follows:
MB: PRO B660M-A CEC WIFI DDR4 (MS-7D37)
BIOS Ver: E7D37IZ1.1A4
BIOS Build Date: 03/31/2022
The Desktop support page doesn't list a bios update as available, nor does MSI Center.
However if I go to the support page for that Motherboard model (https://www.msi.com/Motherboard/PRO-B660M-A-CEC-WIFI-DDR4/support) the latest bios is listed as
7D37v17
2022-07-01
Now from reading this thread, it appears that the desktop MB has an OEM bios whereas the motherboard model is a retail bios. My questions are:
1) Is flashing a retail bios with this forum tool referred to as "cross flashing"?
2) It looks like this is more risky than normal. Why?
3) Is it recommended to just stay with the OEM bios?
Thank you
Administrator
to 1: Yes.
to 2: Because it's not originally indented for the unit and may cause side effects or bricking.
to 3: Yes.
Here I've upload the latest and correct BIOS for your special machine,
E7D37IZ1.1A5 [BIOS Build Date: 07/15/2022],
if you want to flash it.
Malechai
Thank you very much for your reply and answers! I'll stick with the OEM bios.
Also thank you for the latest bios file. May I ask where you found it? That way I can bookmark it for the future. I wasn't able to find it on the support page here: (I could be blind lol)
Administrator
They aren't listed for public, probably because they are not retail versions.
[to avoid flashing to the wrong bios or similar, as they are many different OEM/builders]
escape75
That's interesting ... is the F40 BIOS still the newest for my system:
MSI MAG H410 Infinite (MS-B915)
MSI H410M PRO (MS-7C89)
07/02/2021 F.40
The retail version (H410M PRO) has received 7C89v1A.
Thanks!
Administrator
07/02/2021 F.40
Thanks!
07/02/2021 F.40
List the full BIOS ID, in format: Exxxxyyy.zzz
Which one from those is yours?
This is completely different model.
You have listed me a 2 different models: MS-B915, MS-7C89
escape75
Here's the relevant info from MSINFO32, they are the same system, the data was from HWINFO ...
Official BIOS filename: EB915IMS.F40
System Name MSI
System Manufacturer Micro-Star International Co., Ltd.
System Model MAG H410 Infinite (MS-B915)
System SKU B915.F
Processor Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz, 2901 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. F.40, 2021-07-02
BaseBoard Manufacturer Micro-Star International Co., Ltd.
BaseBoard Product H410M PRO (MS-7C89)
BaseBoard Version 1.1
*I believe this uses the H410M PRO board and it's identified as such to HWINFO.
Administrator
Enter in BIOS Setup, then check the BIOS version from there.
