See info below. Thanks!Enter in BIOS Setup, then check the BIOS version from there.
That's strange,- but maybe it's because a Canadian model.Don't have info about this unit, check it with MSI here:
>>How to contact MSI.<<
Ok, well I do have an SPI programmer and a backup done with the Intel FPT toolOn a paper that's totally different model.
If you gonna cross-flash it, you must be prepared in a case of bricking and non boot, and for HW BIOS chip re-flashing with SPI Programmer.
Can I use this to roll back an A320M-A PRO MAX update???This tool will allow automated flashing MSI boards from UEFI Shell.
Important:
Do NOT use it on a MSI AMD boards from 3xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
How to use:
Download the tool from the link:
Forum UEFI Shell Flash tool [V1.19]
or use special version for Blind Flashing:
For Blind Flashing only: Forum UEFI Shell Flash tool [V1.19]
[prepare the USB key for flashing,[see details below how to prepare it] then shutdown the PC,
General instructions for USB key preparation within Windows for both versions:
and extract all contents over the USB key, [FAT32 formatted]
copy/extract the folder structure As Is to the USB key.
Do not omit the folders and sub-folders.
I.e: USB key root structure should looks:
then also add/copy/extract desire MSI UEFI BIOS that you want flash,
on USB key main/root (\) folder.
for example i want to flash a E7A34AMS.M90 BIOS,
and copied the BIOS file on USB key main/root folder/directory:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
Then boot from USB key,
in UEFI Mode,
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
Yeah, I'm wondering if converting to an H510M PRO would be a good choice as it's had quite a few BIOS updates compared to mine:It's because they are build with a different security feature and you are trying to do a cross-flash.
Like here:
Should be this one, most likely a Winbond 25Q128JV, 128 MBit (16 MB), working with 3.3V.Lastly any idea where the BIOS Chip is located on the Z390M Gaming Edge AC?
