Forum UEFI Shell Flash tool [V1.26] for MSI boards! ✔
Administrator
I just signed up to this forum to thank you and to confirm that the tool works with MSI A320m PRO VD/S.
Restored from 7A36v2L4(Beta version) to 7A36v2H successfuly.
Thank you for the info and update. :emot-tip-wink:
P.S: Preparing a new tool update soon.
m09135
Worked on B350 Tomahawk like a charm.
Downgraded From 7A34v1Q7(Beta version) To 7A34v1M
Thanks Svet!
Administrator
Works fine to downgrade on MSI A320m Pro-VH Plus. I use Blind Flashing V 1.19 -
Great, thanks for feedback.
Thanks Svet!
Super, thanks for the info.
Version updated to V1.24
Will prepare later a detailed guide and what's new.
In short guide for now:
Ensure success messages (and green dots) and close the tool.
Then reboot the computer and boot from USB key to proceed with flashing as usual.
LeoF04
I apologize in advance for the use of Google translator, my English is not the best and I prefer to rely on Google's.
I have been using Blind Flashing around 5 times on an MSI A320M Pro-Vh Plus to downgrade from version "7B07v3I3" to "7B07v3E" of it, for configuration and comfort reasons.
But now a problem arose, when I try to perform the Blind Flashing, the flashing is not performed and the screen stays black for 30 minutes (I was waiting until that waiting time, I don't think there is a limit) with the peripherals turned on.
The only "weird" change I made was to change some windows settings to optimize the use of the hard drive, which was being used at 100%. But I have reverted all the settings to how they were before, or so I think, maybe there is one that I have to activate / deactivate to perform this Flash.
Basically the reason for this Blind Flashing is to enter a previous version of the BIOS compatible with my previous processor and current graphics (Since it is not compatible in the current BIOS) to be able to modify the configuration and thus activate the "Core Performance Boost", "SVM Mode" and the "PBO".
I am also looking for help to know if these options can be activated by other means than entering the BIOS, such as through CMD.
Thank you in advance for reading this text and I apologize for taking so long.
Hardware:
MB: MSI A320M Pro-VH plus (Bios: 7B07v3I3)
CPU: Ryzen 3 4100
RAM: HyperX Fury 1x8GB DDR4 GDDR5
VGA: Sentey Radeon Rx 560 4gb
HDD: WDC WD10EZEX-00BN5A0 1TB
More info:
Current Bios Version: 7B07v3I3
Bios to downgrade: 7B07v3E
Administrator
@LeoF04
It's hard to understand what you trying to do or what happens.
You don't have a screen when you enter in bios setup?
Updated 1st post with more pics and details about newest version.
LeoF04
I was able to resolve Blind Flashing.
The only change I made was to remove the SATA cables from the MB.
My problem was that I couldn't do Blind Flashing but it was strange because before I could do it with the same components of my PC.
And I had another problem but I'm going to open a new thread.
I appreciate your help and since I'm here Blind Flashing works correctly in its version 1.19 with the MB A320M Pro-VH Plus for BIOS downgrade (Probably also for upgrade), you do a very good job @Svet ! Thank you!
Administrator
Updated version to V1.25
* minor optimizations
* update messages instructions for CPF while and after flashing.
EDIT: Also updated Blind flash version too and instructions.
The CPF is Auto Available (and can be Enabled) only for supported BIOSes.
The new style also has Auto BIOS validation that checks for the BIOS integrity (and USB key integrity respective)
after transferring the necessary data over the USB drive,
to ensure firmware & USB key is a healthy before attempt BIOS flashing.
Administrator
Update:
Both versions updated to V1.26:
* Updated tool installer to 64bit
* Various of different tweaks and optimizations. [more speed, less memory usage]
burz0158602d9
Hi, in your first post you wrote that Secure Boot must be disabled. I have to use the blind flash method because I have only a black screen. On this motherboard Secure Boot is enabled, so am I correct that because of that the flash tool won't work?
Administrator
to able to boot usually yes, but you can have a try to find out
virgil2156e02dd
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
How to use:
Download the tool from the link:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
For Blind Flashing only: Forum UEFI Shell Flash tool [V1.26]
Does anyone know where I can find the blind flash utility file that is not corrupted? I have downloaded it several times now with different web browsers on two different computers and the file is corrupted. Never mind, I did some thinking and found out that someone or something had changed it from a .zip file to a .rar file and when I used WinZip to open it, it was okay, no problems. I was finally able to extract the file. I hope doing this blind flash will fix the memory problems and then recognize the memory I put in it and also recognize an i9 11th gen CPU.
Administrator
Anyone know where I can find the blind flash utility file that is not corrupted? I have downloaded several times now with different web browsers on two different computers and the file is corrupted.
I just double checked and there is no issue. It's downloading and runs just fine.
What message you got exactly?
virgil2156e02dd
I figured it out after a few minutes and instead of using winrar to extract it, I used winzip and apparently it was a .zip file originally and some how got renamed to a .rar file and winrar could not recognize it as a valid .rar file. So crisis averted and on Monday when I talk with a MSI tech I will check to see which of the bios's to flash, The current one is just for a secure boot and I don't know if it will update the board to recognize the i9 11th gen CPU and my memory at the same time.
Administrator
PC need to able to boot to use it. If the compute can't boot, then won't work.
What PC mainboard you have? [current BIOS version?] and what CPU you want to use?
virgil2156e02dd
I have a MSI MPG Z490 GAMING EDGE WIFI board and I have the Intel i9 11th gen CPU and trying to use Mushkin Enhanced RGB Redline 32GB (2 x 16GB) DDR4 3600 (PC4 28800) Desktop Memory, DDR4 3600 (PC4 28800), Timing 18-22-22-42, CAS Latency 18, Voltage 1.35V. the memory basically matches the memory that is on the compatibility list but is not recognized on the board and the DRAM light comes on.
Administrator
Can't you use another different temporary memory stick to boot and update the bios before try with that memory again?
virgil2156e02dd
I have tried two different memory sticks, I have paid over $300 on the memory for this board already and on a disabled American Veterans income I can't afford to buy any more memory. Had I known that MSI was so proprietary I would not have purchased the board.
Administrator
You can borrow some other memory try to isolate the issue.
One or more memory stick(s) could be defective. Try boot with 1 memory stick only in recommended DIMM slot.
[test with each one of them alone]
Or could be bented pins on the socket or too much pressure from the heatsink and not to be the memory.
In anyways better open new own topic for troubleshooting the issue.
