Forum UEFI Shell Flash tool [V1.32] for MSI boards! ✔
Pro
M-FLASH will not see an update file with a non-matching filename. Everything before the dot, and first character after, have to match with your installed BIOS.
And no, renaming the file will not work, it will see the file then, but it still won't update.
Most likely your board is from a pre-built system that gets its own seperate BIOS updates, and you cannot use the normal BIOS updates for the retail board. For the boards on those pre-built systems, they sometimes use a custom BIOS which might be modified to leave out certain options (for example, to prevent any overclocking that could mess with their cooling concept, which is probably tailor-made for that system).
If you want the official BIOS updates because they are way ahead than the ones for your pre-built PC (if the company that built the PC even offer them), then your only chance is to flash the official MSI BIOS using the flash tool from this thread, at your own risk of course. You should make sure that some key CPU- and cooling-related settings will be set roughly similar afterwards though, or at least take into consideration the previous settings, as they might be adjusted to your system's cooling capabilities.
loiclebeau515ce02e7
alright thanks for the reply then does the tool on this website support b350i MB. because in the first page the author said to not use it on3xxx motherboard
Pro
Then probably it's not safe there for some reason. Did you check with the vendor who offered this pre-built PC, if they provide any BIOS updates?
Pro
Hmm yeah, cheap used boards which are taken from pre-built systems, without informing the buyers about the problems that this can cause with the BIOS updates...
andreuu15e202ee
I install the x470 gaming plus AL bios and now have a very hard soft brick. My video card is r9 380, I think so old the switch on it is go faster not uefi/mbr, in any case I have black screen and despite trying many things I cannot access bios to turn secure boot off. I believe the video card is why.
Can I remove the pcie video card and hope that 1.27 blind will downgrade the bios to a bios that defaults to secure mode off so I can reset cmos and get my puter back and not a hard brick? Oh I'm gunna try anyway seems like it's pretty idiot proof, but I'm proof myself 😝
Administrator
You can have a try.
From which BIOS you have flashed and how? Can you list full system specs. too, see >>Posting Guide<<
Administrator
FYI:
Tool version been updated to V1.28
with more optimizations, improvement and some new features and updated new look.
Administrator
Tool version been updated to V1.29
- Increase startup speed.
Administrator
Tool version been updated to V1.30
* fixed bug: In a case of BIOS/USB key corruption, after shows the error message the tool hangs.
* other different improvements and micro optimizations
daniel3700156702d3
UEFI Shell Flash tool [V1.30]
Is this tool designed as a clean bios upgrade tool (so I don't brick my Z490).
or is it a general tool for bios updates...(and doesn't address the bricking epidemic).
Also, will the latest bios still kill my board, or are we past that ? Thanks.
MPG Z490 GAMING PLUS
i7-10700
Administrator
i7-10700
I don't know what clean bios upgrade means, but it should not brick your Z490 board.
I don't know what bricked your board in the past,
I guess you flashed before with M-Flash or LiveUpdate and this bricked your board?
I can't comment other flashing methods why they bricked your board if you mean this.
It's for general, but has special support for Z490 series.
It don't address such issues as other flashing ways are completely not related to the tool.
If you flash with tool to the latest BIOS version it should not brick your board, so far never did.
However any BIOS flashing is risky by nature and flashing BIOS accidents can happens due one or another reason,
means BIOS flashing is always at own risk.
daniel3700156702d3
Hundreds of Z490 boards were bricked, not by user error (standard bios update methods), but by an undiagnosed flaw in the board's hardware or coding software.
I just want to know if it is still ongoing, or if your tool and upgrade path has the "very very low probability" of bricking.
My Z490 never bricked; I read the threads and lived the horror story's along with them...
I want the "clean" bios "upgrade fix", not the "desolder-reprogram-chip-flashing-"nightmare fix".
...as do You I'm sure !
Sincerely, thank you for your focus, and the tools...(80,000 posts!) """"""""Daniel
Administrator
Yes it is. At least for Z490 there are none reported brick cases, flashing to the latest BIOS version.
I also tested personally same msi class board to the latest BIOS with the tool multiple times, always goes fine.
:emot-tip-wink:
Dan111bas15d302ed
hey guys,
i use a z790i Edge (without Bios Flash button) and tried to update a self modded Bios file with this tool, but got "secureflash rom verify Fail".
is there anything i can bypass the verification, without using a SPI Programmer?
Administrator
hey guys,
It may not work even with SPI Programmer, the modded BIOS may refuse to run, depends of what security level those platform/BIOS are using.
Hello, i really need to downgrade the bios for my A320M PRO VD/s, as i cant do it on the normal M-flash mode because it doesnt allow me. Im stuck on two of the latest beta bios versions, but i need to go back to the previous ones. Will this tool work for my motherboard?
Alan J T
Demon God
