- Nov 20, 2003
Download tool from the link:
Important:
Do NOT use it on a MSI AMD boards from 3xx boards Series. [like X370/B350]
(its OK to use for X399 AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
PRO Z790-S WIFI
MPG Z790 CARBON WIFI
MPG Z790 EDGE WIFI DDR4
MAG Z790 TOMAHAWK WIFI DDR4
MPG Z790 EDGE WIFI
Z790 GAMING PRO WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P WIFI DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI DDR4
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
How to use:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
efmled date=1563998092 said:You can attach the link to your top message in this discussion theme.Thank you Again !
Here is the link to video:
[youtube]
