Forum UEFI Shell Flash tool [V1.42] for MSI boards! ✔
Administrator
Download tool from the link:
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 and A320, AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
PRO Z790-S WIFI
MPG Z790 CARBON WIFI
MPG Z790 EDGE WIFI DDR4
MAG Z790 TOMAHAWK WIFI DDR4
MPG Z790 EDGE WIFI
Z790 GAMING PRO WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P WIFI DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI DDR4
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
Updated tool version to V1.32
* Minor optimisations
* Added mini display status, with current status and detected numbers of USB devices in the system.
* Updated ME-FW for Z490 Series to 14.1.70.2228 (released BIOSes few days ago by MSI after ~2 years from prevision FW update to handle latest security fixes and vulnerabilities)
Updated tool version to V1.33
* implement self update feature
* a lot of performance and memory optimizations
* hundreds of other small tweaks, improvements, code refactoring
Updated tool version to V1.34
* minor refactoring
* updated self-crafted ME-FW for MSI Z790 boards to 16.1.30.2264
older version V1.33 and above can self-update to the latest one
Updated tool version to V1.35
* minor bug fixes. [sometimes in rare case was possible to throw error msg. while preparing the USB key]
Updated tool version to V1.36
* updated and patched 2nd flasher
* add support for B650 & X670 board Series
* applied different optimizations and improvements.
Updated tool version to V1.37
-add enhanced flash support[ME-FW Flash] for B760 Series:
MPG B760M EDGE TI WIFI
MPG B760I EDGE WIFI
MPG B760I EDGE WIFI DDR4
MAG B760 TOMAHAWK WIFI
MAG B760 TOMAHAWK WIFI DDR4
MAG B760M MORTAR MAX WIFI
MAG B760M MORTAR MAX WIFI DDR4
MAG B760M MORTAR WIFI
MAG B760M MORTAR
MAG B760M MORTAR WIFI DDR4
MAG B760M MORTAR DDR4
MAG B760M MORTAR WIFI II
MAG B760M MORTAR II
PRO B760-P WIFI
PRO B760-P WIFI DDR4
PRO B760-P DDR4
PRO B760-VC WIFI
PRO B760-VC
B760 GAMING PLUS WIFI
PRO B760-P DDR4 II
PRO B760M-A WIFI
PRO B760M-A WIFI DDR4
PRO B760M-A DDR4 II
PRO B760M-A DDR4
PRO B760M-P
PRO B760M-P DDR4
PRO B760M-G
PRO B760M-G DDR4
PRO B760M-B
PRO B760M-E
PRO B760M-E DDR4
Updated tool version to V1.38
*Updated self-crafted ME-FW for Z790 and B760 boards from 16.1.30.2264 to 16.1.30.2330
Updated UEFI flash-tool version to V1.39
  • * Fixed issue for Z490 Series:
    • - Unable to perform ME-FW update if the current installed ME-FW version is too old [like: 14.0.xx.xxxx]
  • * Modify Multi tank update to do not flash Non Boot part, if the target platform ID is different or not updated successful.
Updated UEFI flash-tool version to V1.40
  • - Fixed issue: Boot to shell unable to map USB key if they are too many devices in the system.
    • - Add: Display AGESA version for supported BIOS files.
    • - Minor improvements.
    • - Minor GUI update.
Updated UEFI flash-tool version to V1.41
  • * Update: Extend AGESA support detection.
  • * Add: Display Intel ME-FW version for supported BIOS files. [different bases in different colours]
Updated UEFI flash-tool version to V1.42
  • * Update: Optimize and speed-up detection for AGESA & Intel ME-FW
    • * Update: Secondary flasher
    • * Add: Add support for additional custom flash command for 256MBit Intel BIOSes
How to use:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:
I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
You can attach the link to your top message in this discussion theme. :) Thank you Again !
Here is the link to video:
[youtube]
Update:
Flash tool been updated ver. V1.11 with many new features and add support for many new MSI boards.
index.php
index.php
Update:
Flash tool been updated ver. V1.12,
add enhanced support and detection for MEG Z490 GODLIKE for ME FW Update purpose,
and implement various of new functions.
Simulations shots:
Version updated to V1.13
Add extra support for all MSI Z490 Series to include ME FW auto re-flashing along with BIOS flashing.
MEG Z490 UNIFY
MEG Z490I UNIFY
Z490-A PRO
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
Version updated to V1.14
* Code refactoring
* Speed optimizations
* Added additional error handles
* Modify external code[shell script] for better visual appearance[for human reading]
* Fix minor bug in some of the error cases. [where shows 2 different error messages at once if specified error event occur]
Important:
(its OK to use for X399 AMD models as 3xx exception)
MEG Z490 UNIFY
MEG Z490I UNIFY
Z490-A PRO
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
How to use:
Download the tool from the link:
Forum UEFI Shell Flash tool [V1.14]
and extract all contents over the USB key, [FAT32 formatted]
copy/extract the folder structure As Is to the USB key.
Do not omit the folders and sub-folders.
I.e: USB key root structure should looks:
then also add/copy/extract desire MSI UEFI BIOS that you want flash,
on USB key main/root (\) folder.
for example i want to flash a E7A34AMS.M90 BIOS,
and copied the BIOS file on USB key main/root folder/directory:
Then boot from USB key,
in UEFI Mode,
UEFI USB your drive
Hallo, i'm need an older version of this tool. Like Version V 1.09 that support X370 Boards. Because i would something to try with older Agesas . Where can i find it ?
This one has the same properties for X370 like older version,
but BIOS types changes with further BIOS updates and roll back from GSE to normal one was causing a bricks for those boards with regardless of version used.
From which BIOS version to which one you want to flash?
ahh ok the version is the same as the old. also should run ?
but BIOS types changes with further BIOS updates and roll back from GSE to normal one was causing a bricks for those boards with regardless of version used. .
sorry my english isn't the best what does this exactly means . GSE to normal one was causing a brick for those boards with regardless of version . does it mean you can damage the board if you flash with this newer util or what does it mean?
x370 gameing pro
from actualy one to 7A33?? or so don't know the exactly bios name now. to patch it to agesa 1003ab . I make this for an longer time with that tool, but i can find only the bios not the tool . In old version you can read in the description . Not support for x470 or newer or so .
if older version worked for you, the newest one also will works.
with newest GSE BIOSes, switching back to older one was causing a brick with older flasher. [i expect the same to be for newest too]
Don't think you can flash to a bios that works for new version yet retains older BIOS UI, I've tried this tool for and wouldn't post (b450 tomahawk) but managed to flashback and get working. I'm a sucker for punishment though so I might try the pre lite E7C02AMS.170 version. Pray for me
Ok thanks . If in the old version the flash works. It works in the new version of flasher too. Ahh ok so do you mean this. ? Then the usage of x370 doesn't work it this usage should be valid for old version of flasher tooo . ok thanks. because the usage in past was it doesn't work on x470 but on x370 or so . okk thanks for answer :)
Important:
MEG Z490 UNIFY
MEG Z490I UNIFY
Z490-A PRO
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
How to use:
in UEFI Mode,
UEFI USB your drive
Hi.. I have a B450M pro vdh board with Ryzen 7 2700x cpu. I tried to upgrade to the latest bios using m-flash utility from the previous bios. I had the latest bios file in a bootable usb which had win10 setup in it. I had no idea that the usb drive should be empty and fat32 formatted. The flashing process went fine but after the reboot my system does not start. Only the cpu led is constantly on and cpu whirls so fast. Some people suggest that the upgraded bios does not support my ryzen 2700x anymore.. I want to downgrade to the previous bios I had before.. just to confirm, will this utility work on my b450m pro vdh?
Thank you in advance..
open new own topic in the correct area, as this is not related to the tool.
