Forum UEFI Shell Flash tool [V1.42] for MSI boards! ✔
Administrator
Download tool from the link:
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 and A320, AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
PRO Z790-S WIFI
MPG Z790 CARBON WIFI
MPG Z790 EDGE WIFI DDR4
MAG Z790 TOMAHAWK WIFI DDR4
MPG Z790 EDGE WIFI
Z790 GAMING PRO WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P WIFI DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI DDR4
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
Updated tool version to V1.32
* Minor optimisations
* Added mini display status, with current status and detected numbers of USB devices in the system.
* Updated ME-FW for Z490 Series to 14.1.70.2228 (released BIOSes few days ago by MSI after ~2 years from prevision FW update to handle latest security fixes and vulnerabilities)
Updated tool version to V1.33
* implement self update feature
* a lot of performance and memory optimizations
* hundreds of other small tweaks, improvements, code refactoring
Updated tool version to V1.34
* minor refactoring
* updated self-crafted ME-FW for MSI Z790 boards to 16.1.30.2264
older version V1.33 and above can self-update to the latest one
Updated tool version to V1.35
* minor bug fixes. [sometimes in rare case was possible to throw error msg. while preparing the USB key]
Updated tool version to V1.36
* updated and patched 2nd flasher
* add support for B650 & X670 board Series
* applied different optimizations and improvements.
Updated tool version to V1.37
-add enhanced flash support[ME-FW Flash] for B760 Series:
MPG B760M EDGE TI WIFI
MPG B760I EDGE WIFI
MPG B760I EDGE WIFI DDR4
MAG B760 TOMAHAWK WIFI
MAG B760 TOMAHAWK WIFI DDR4
MAG B760M MORTAR MAX WIFI
MAG B760M MORTAR MAX WIFI DDR4
MAG B760M MORTAR WIFI
MAG B760M MORTAR
MAG B760M MORTAR WIFI DDR4
MAG B760M MORTAR DDR4
MAG B760M MORTAR WIFI II
MAG B760M MORTAR II
PRO B760-P WIFI
PRO B760-P WIFI DDR4
PRO B760-P DDR4
PRO B760-VC WIFI
PRO B760-VC
B760 GAMING PLUS WIFI
PRO B760-P DDR4 II
PRO B760M-A WIFI
PRO B760M-A WIFI DDR4
PRO B760M-A DDR4 II
PRO B760M-A DDR4
PRO B760M-P
PRO B760M-P DDR4
PRO B760M-G
PRO B760M-G DDR4
PRO B760M-B
PRO B760M-E
PRO B760M-E DDR4
Updated tool version to V1.38
*Updated self-crafted ME-FW for Z790 and B760 boards from 16.1.30.2264 to 16.1.30.2330
Updated UEFI flash-tool version to V1.39
  • * Fixed issue for Z490 Series:
    • - Unable to perform ME-FW update if the current installed ME-FW version is too old [like: 14.0.xx.xxxx]
  • * Modify Multi tank update to do not flash Non Boot part, if the target platform ID is different or not updated successful.
Updated UEFI flash-tool version to V1.40
  • - Fixed issue: Boot to shell unable to map USB key if they are too many devices in the system.
    • - Add: Display AGESA version for supported BIOS files.
    • - Minor improvements.
    • - Minor GUI update.
Updated UEFI flash-tool version to V1.41
  • * Update: Extend AGESA support detection.
  • * Add: Display Intel ME-FW version for supported BIOS files. [different bases in different colours]
Updated UEFI flash-tool version to V1.42
  • * Update: Optimize and speed-up detection for AGESA & Intel ME-FW
    • * Update: Secondary flasher
    • * Add: Add support for additional custom flash command for 256MBit Intel BIOSes
How to use:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:
I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
You can attach the link to your top message in this discussion theme. :) Thank you Again !
Here is the link to video:
[youtube]
So you did it like this, right?
But you also have a Flash BIOS Button, have you tried that? With the PC off, set the switch to BIOS A, then flash it like so (now i have to describe it after all):
1. Download the latest BIOS file from the MSI support site for your board and extract it.
2. Take a USB stick and format it to FAT32 (it's best for it to have a size of 32 GB or less). You can also try Rufus for formatting, as FAT32 non-bootable.
3. Rename the extracted (!) BIOS file to MSI.ROM and save it to the root of your USB flash drive / USB stick (not in a subfolder).
4. Plug the USB flash drive / USB stick that contains the MSI.ROM file into the marked Flash BIOS Port (!) on the rear I/O panel.
5. With the PC off, press the Flash BIOS Button, and the LED should start flashing for about 5-8 minutes and then the board reboots.
If it all doesn't work, i wouldn't flash it with an external programmer, it's too much hassle. If your BIOS B is updated to the latest version, just use that and treat your board like a normal one-BIOS board that also has a Flash BIOS Button. With that button alone, you should not need an external programmer, and especially not if one of the BIOSes still works.
Thank you for your reply! I tried this method as well, doesnt work!
Then don't bother, stay on the second BIOS. Assuming you don't plan to turn off your PC again during the next BIOS update.
Has anyone successfully cross-flashed an OEM BIOS to the retail version on a prebuilt MSI motherboard? I am attempting to upgrade an OEM prebuilt MSI PRO Z690-A motherboard (version 'E7D25IZ1.AA9') to the retail MSI PRO Z690-A BIOS (version 'E7D25IMS.AF0'). Im currently stuck on "Error: Secure Flash function is not supported on this file".
Hi @Svet
I'm wondering if you can help me out. I have a Trident X 12 pre-build that is using a retail motherboard, Z690I Unify, but the BIOS installed on the board is designed specifically for the pre-build and I wasn't able to get the flash tool to work to switch the BIOS to the retail software. I tried twice, first with the latest update and second with the very first and both times I got the 1e Error: Secure Flash function is not supported on this file. Thumb drive is FAT32 formatted and I followed the steps as directed at the beginning of this thread.
I'm 1000% sure that I am using a a retail board in my pre-build the serial# is MS-7D2921_M11B493767 so I don't understand why the flash tool didn't work to switch me from BIOS version EB924IMS.910 to E7D29IMS.1F0
I had already asked about this in another thread and was directed here after the flash tool didn't work for me. Here is the link to that thread https://forum-en.msi.com/index.php?threads/wrong-bios-loaded-to-motherboard.391238/
I will also attach thumbnails of the BIOS showing the build version and my board serial # along with the two attempts I did with the flash tool.
Thank you for any and all help you can provide.
Hi @Svet
I was able to cross flash from OEM firmware to retail using this method via Intel CSME FWUpdate.
Important:
(its OK to use for X399 AMD models as 3xx exception)
MEG Z490 UNIFY
MEG Z490I UNIFY
Z490-A PRO
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
PRO Z790-S WIFI
MPG Z790 EDGE WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
How to use:
UEFI USB your drive
Svet can you help me please? I have MSI A320M PRO-VH PLUS motherboard and I accidently updated to the latest(beta) version of bios. Now I want to downgrade any stable version but when I try to M-Flash it says you cannot upgrade old version of bios for system quality etc.. There is no button behind the motherboard so I also can't downgrade that way. I searched and find your tool but you noted: do not use 300 series like mine. What can I do at this moment. Can you help?
For A320 if I remember it correctly it was working fine.
Because it's a prebuild system and their BIOSes are using different security behaviours.
You can try to flash to older version, then to try to cross-flash to the mainboard retail BIOS.
Unfortunately there's only one version of the pre-build BIOS which I have currently.
Is it possible to do a full BIOS erase and then flash a new one or just a different process that can be attempted?
It's different process. But also will lead to specified BIOS's data lost. Like when flashing bios chip with HW Programmer.
It worked for me thanks a lot. But this time I can't overclock my cpu(ryzen 5 1600). I tried 3.6ghz, 3.75ghz, 3.9ghz and 4ghz all with 1.4V override setting and none of them worked. And when I check HardwareInfo it works max 3.4ghz sometimes 3.2 and below. When I benchmark in cpu-z I get 2600 multicore 315 single core score.(Ryzen 5 1600's reference 3100 multicore). What should I do this time? Is there anything that I can do or do I must upgrade my cpu?
Note:I was using 1050ti and upgraded to 1070 but this time i have cpu bottleneck(while playing cs and other games cpu and gpu usages are %30-%40 percent maybe below). This is why I try to overclock.
I have: Ryzen 5 1600 + Msi gaming x gtx1070 + 8x2 3200Mhz Corsair Ram + 500W Psu
Haven't find enough time to reply in details to each reply, been busy with next version that soon will be released.
For OC related questions best open new topic in the proper area.
Two questions:
1) I searched the thread and don't see any of the B760 boards being mentioned as being supported or not by the tool - specifically the PRO B760-VC WIFI in my system?
2) If flashing via the tool goes wonky (corrupted flash/computer won't fully boot, etc.) - can it be recovered by the tool with an older BIOS version file?
Hi I have a older MSI B360- A pro motherboard that has a beta bios from microcenter (2.M4) since it's a prebuilt board, and the latest bios from the website (IMS.2D0) isn't readable since it's OEM, my question is can I use this tool to crossflash the current bios to the one on the msi website? I also would like 9th gen coffee lake CPU support, I don't know if my board will work the the i7 9700 with the OEM bios.
MPG B760I EDGE WIFI
MAG B760M MORTAR
MAG B760M MORTAR II
PRO B760-P WIFI
PRO B760-P DDR4
PRO B760-VC WIFI
PRO B760-VC
PRO B760-P DDR4 II
PRO B760M-A WIFI
PRO B760M-A DDR4 II
PRO B760M-A DDR4
PRO B760M-P
PRO B760M-P DDR4
PRO B760M-G
PRO B760M-G DDR4
PRO B760M-B
PRO B760M-E
PRO B760M-E DDR4
Depends. What's current BIOS ver. installed?
Two questions:
It's supported
That's up to board's recovery capabilities.
