Forum UEFI Shell Flash tool [V1.42] for MSI boards! ✔
Administrator
Download tool from the link:
Important:
Do NOT use it on a MSI AMD boards from 3
xx boards Series. [like X370/B350]
(its OK to use for X399 and A320, AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
PRO Z790-S WIFI
MPG Z790 CARBON WIFI
MPG Z790 EDGE WIFI DDR4
MAG Z790 TOMAHAWK WIFI DDR4
MPG Z790 EDGE WIFI
Z790 GAMING PRO WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P WIFI DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI DDR4
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
Updated tool version to V1.32
* Minor optimisations
* Added mini display status, with current status and detected numbers of USB devices in the system.
* Updated ME-FW for Z490 Series to 14.1.70.2228 (released BIOSes few days ago by MSI after ~2 years from prevision FW update to handle latest security fixes and vulnerabilities)
Updated tool version to V1.33
* implement self update feature
* a lot of performance and memory optimizations
* hundreds of other small tweaks, improvements, code refactoring
Updated tool version to V1.34
* minor refactoring
* updated self-crafted ME-FW for MSI Z790 boards to 16.1.30.2264
older version V1.33 and above can self-update to the latest one
Updated tool version to V1.35
* minor bug fixes. [sometimes in rare case was possible to throw error msg. while preparing the USB key]
Updated tool version to V1.36
* updated and patched 2nd flasher
* add support for B650 & X670 board Series
* applied different optimizations and improvements.
Updated tool version to V1.37
-add enhanced flash support[ME-FW Flash] for B760 Series:
MPG B760M EDGE TI WIFI
MPG B760I EDGE WIFI
MPG B760I EDGE WIFI DDR4
MAG B760 TOMAHAWK WIFI
MAG B760 TOMAHAWK WIFI DDR4
MAG B760M MORTAR MAX WIFI
MAG B760M MORTAR MAX WIFI DDR4
MAG B760M MORTAR WIFI
MAG B760M MORTAR
MAG B760M MORTAR WIFI DDR4
MAG B760M MORTAR DDR4
MAG B760M MORTAR WIFI II
MAG B760M MORTAR II
PRO B760-P WIFI
PRO B760-P WIFI DDR4
PRO B760-P DDR4
PRO B760-VC WIFI
PRO B760-VC
B760 GAMING PLUS WIFI
PRO B760-P DDR4 II
PRO B760M-A WIFI
PRO B760M-A WIFI DDR4
PRO B760M-A DDR4 II
PRO B760M-A DDR4
PRO B760M-P
PRO B760M-P DDR4
PRO B760M-G
PRO B760M-G DDR4
PRO B760M-B
PRO B760M-E
PRO B760M-E DDR4
Updated tool version to V1.38
*Updated self-crafted ME-FW for Z790 and B760 boards from 16.1.30.2264 to 16.1.30.2330
Updated UEFI flash-tool version to V1.39
  • * Fixed issue for Z490 Series:
    • - Unable to perform ME-FW update if the current installed ME-FW version is too old [like: 14.0.xx.xxxx]
  • * Modify Multi tank update to do not flash Non Boot part, if the target platform ID is different or not updated successful.
Updated UEFI flash-tool version to V1.40
  • - Fixed issue: Boot to shell unable to map USB key if they are too many devices in the system.
    • - Add: Display AGESA version for supported BIOS files.
    • - Minor improvements.
    • - Minor GUI update.
Updated UEFI flash-tool version to V1.41
  • * Update: Extend AGESA support detection.
  • * Add: Display Intel ME-FW version for supported BIOS files. [different bases in different colours]
Updated UEFI flash-tool version to V1.42
  • * Update: Optimize and speed-up detection for AGESA & Intel ME-FW
    • * Update: Secondary flasher
    • * Add: Add support for additional custom flash command for 256MBit Intel BIOSes
How to use:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:
I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
You can attach the link to your top message in this discussion theme. :) Thank you Again !
Here is the link to video:
[youtube]
@nkyadav
E0? E3? Those are unknown to me
Can you tell full BIOS ID of those?
You mean dual BIOS?
I'm confused what is E0 , E3 and what you call "slot. Can you clarify better?
Dual slot == dual BIOS, with a switch to select one or the other.
As for E3 versus E0 - the MSI X570 GODLIKE UEFI fw versions come in major version like follows: 7C34v1E. The 1E is the designation for the major revision, with a following number (1,2,3, etc.) for Beta and 0 for the final release.
Currently, for example, there is a new 7C34v1F1 (Beta version), but the last stable release is 7C34v1E, which, when extracted, has a name E7C34AMS.1E0.
The actual file names are as in my screenshot:
When I sent a message to MSI support, they automatically generated an RMA for the board, but want 15-30 days turnaround, and I don't have a backup system and cannot afford the downtime right now. So, I was hoping that your utility might offer some recourse to allow me to get both 'BIOS' working correctly.
The worst part is that I used the latest MSI Center 1.0.24 to download and apply the E7C34AMS.1E0 fw update over E7C34AMS.1E3, which rebooted the machine and ran the M-Flash utility as it is supposed to - but it froze for well over 3 hours, as mentioned, and I had no recourse but to reboot (I had some really bad thunderstorms moving into the area and I decided to take my chances with the UEFI fw update being incomplete versus leaving my computer on during the storms).
I hope that helps explain what I mean. If I need to provide more info, please let me know and I will.
Hello dear SVET and thanks for all the help. I have purchased your tool for set up EC parameters. Now i got some problems with mainboard. I got B450 bios on X470 board and its max version. Is there some tool to apply it to X470? I have purchased the board with this bios. Board is MS-7B79 and its X470 gaming plus max. Thanks and sorry for my english.
You can use the tool in this topic to cross-flash and re-flash to correct BIOS if that's what you mean,
direct link:
and instructions are in the 1st post.
Link to the latest and correct BIOS for X470 gaming plus max:
How is that on h110 mobo when using afudos there is an error when /me command is issued ?
It says somthing like "this bios does not support entire me flashing"
I have no problems flashing me region as well as bios one using m-flash or FPT tool or even Flashrom under linux but afudos always fails with me region. Why is that?
This tool is a lifesaver for me and it works on MSI Z370 Gaming M5 (7B58) like a charm. Did manage to flash my mobo with latest beta bios (7B58v1B2). The genuine M-flash tool stops working and don't know why. Just a black screen after reboot and so on. Stupid boot loop black screen restart crap thing... only Cmos reset helped but no flash then. This little software did the trick an reminded me the times when the easiest, best and simplest way that always works was the DOS method :).
Big thanks!
Hi there,
I have a Medion PC with an MSI z490 gaming edge wifi mainboard (MS-7C79 ver.1.1) with an OEM firmware from Medion (E7C79W0X.205) can I replace this version with the UEFI v1.16 tool to the retail version? The new BIOS version supports Win11 according to the homepage. (Version E7C79IMS.1A0) Thank you very much !!
Hi there,
If you want to cross-flash at own risk, yes you can. Else check with your OEM vendor for updates.
If you plan to use the tool for cross-flashing,
for this particular case to match the ME-FW version,
do a step update as follows:
1st Update with the forum flasher tool to BIOS version 1.3:
and when its done, do a 2nd flashing this time with M-Flash to the latest version 1.A:
Hello Svet!
Thank you for your reply! Can I also use the version https://download.msi.com/bos_exe/mb/7C79v16.zip with the MSI UEFI Flashtool V1.16? I have installed an 11th Gen Intel Processor (11900KF). My concerns are that afterwards with version 1.3 the CPU is no longer recognized. I will give my OEM vendor another chance to make improvements. But if that doesn't help, then I have to install this retail bios myself! Is the MAC address WLAN + LAN saved on another chip? Best regards Mario
That tool works for laptop @Svet
I need to upgrade to 60H version for support EFI
Thanks
Thanks @Svet for your time and answer!
But can you tell me some path or tool for do this process that a need to do for support UEFI in my old laptop[CR41_0M] at my own risk?
I mean, I want to flash a 60H version of BIOS, that is for W8 and with UEFI support in my board.
Best regards
Hello Svet!
Hello Mario,
I have the same pc like you, with the same problem. Can you tell me if the cross flash works with the tool?
thanks!
@Svet
Can you please help me what to do? I have the same problem as Mario, above here.
I have a pre installed mpg z490 gaming edge wifi. But im missing a lot of features on this MB. So I want It to flash like its an normal board with the original MSI bios software.
If I want to update the bios like the normal way, the files wont show up, wich is a common problem because of the pre installed bios/medion software.
Thanks in advance
You can flash/cross-flash to desired BIOS [at own risk]
just make sure the new BIOS will support your hardware.
Alright thanks @Svet
So from (z490 gaming edge wifi) current bios E7C79W0X.205 to newer version 7C79v18 (for z490 gaming edge wifi), should be possible with the flashtool v1.16? ''yes at my own risk.''
z490 bios driver
or should i first cross flash to v13? (as you mentioned above to supermario), and from there on to the newer ones? The latest one, version 1A is not relevant for me, because i dont use win11.
Check if your CPU used will be supported by that new BIOS.
Thanks for you fast reply @Svet! Really appreciate that!
according to this page from MSI, my i9 11900K is supported from version 7C79v16. That means that it minimal requires this version, and the later ones are also working (i.e v18) i guess?
So do i need to perform a crossflash to v16 first, and after that a normal flash to V18?
