- Nov 20, 2003
Download tool from the link:
Important:
Do NOT use it on a MSI AMD boards from 3xx boards Series. [like X370/B350]
(its OK to use for X399 and A320, AMD models as 3xx exception)
MPG Z490 CARBON EK X
MEG Z490 UNIFY
MEG Z490I UNIFY
MPG Z490 GAMING CARBON WIFI
Z490-A PRO
MPG Z490 GAMING EDGE WIFI
MPG Z490 GAMING PLUS
MAG Z490 TOMAHAWK
MEG Z490 GODLIKE
MEG Z490 ACE
MPG Z490M GAMING EDGE WIFI
PRO Z790-S WIFI
MPG Z790 CARBON WIFI
MPG Z790 EDGE WIFI DDR4
MAG Z790 TOMAHAWK WIFI DDR4
MPG Z790 EDGE WIFI
Z790 GAMING PRO WIFI
Z790 GAMING WIFI
MPG Z790I EDGE WIFI
PRO Z790-P DDR4
PRO Z790-P WIFI DDR4
PRO Z790-P
PRO Z790-P WIFI
PRO Z790-A WIFI DDR4
PRO Z790-A WIFI
MEG Z790 GODLIKE
MEG Z790 ACE
Updated tool version to V1.32
* Minor optimisations
* Added mini display status, with current status and detected numbers of USB devices in the system.
* Updated ME-FW for Z490 Series to 14.1.70.2228 (released BIOSes few days ago by MSI after ~2 years from prevision FW update to handle latest security fixes and vulnerabilities)
Updated tool version to V1.33
* implement self update feature
* a lot of performance and memory optimizations
* hundreds of other small tweaks, improvements, code refactoring
Updated tool version to V1.34
* minor refactoring
* updated self-crafted ME-FW for MSI Z790 boards to 16.1.30.2264
Updated tool version to V1.35
* minor bug fixes. [sometimes in rare case was possible to throw error msg. while preparing the USB key]
Updated tool version to V1.36
* updated and patched 2nd flasher
* add support for B650 & X670 board Series
* applied different optimizations and improvements.
Updated tool version to V1.37
-add enhanced flash support[ME-FW Flash] for B760 Series:
MPG B760M EDGE TI WIFI
MPG B760I EDGE WIFI
MPG B760I EDGE WIFI DDR4
MAG B760 TOMAHAWK WIFI
MAG B760 TOMAHAWK WIFI DDR4
MAG B760M MORTAR MAX WIFI
MAG B760M MORTAR MAX WIFI DDR4
MAG B760M MORTAR WIFI
MAG B760M MORTAR
MAG B760M MORTAR WIFI DDR4
MAG B760M MORTAR DDR4
MAG B760M MORTAR WIFI II
MAG B760M MORTAR II
PRO B760-P WIFI
PRO B760-P WIFI DDR4
PRO B760-P DDR4
PRO B760-VC WIFI
PRO B760-VC
B760 GAMING PLUS WIFI
PRO B760-P DDR4 II
PRO B760M-A WIFI
PRO B760M-A WIFI DDR4
PRO B760M-A DDR4 II
PRO B760M-A DDR4
PRO B760M-P
PRO B760M-P DDR4
PRO B760M-G
PRO B760M-G DDR4
PRO B760M-B
PRO B760M-E
PRO B760M-E DDR4
Updated tool version to V1.38
*Updated self-crafted ME-FW for Z790 and B760 boards from 16.1.30.2264 to 16.1.30.2330
Updated UEFI flash-tool version to V1.39
- * Fixed issue for Z490 Series:
- - Unable to perform ME-FW update if the current installed ME-FW version is too old [like: 14.0.xx.xxxx]
- * Modify Multi tank update to do not flash Non Boot part, if the target platform ID is different or not updated successful.
Updated UEFI flash-tool version to V1.40
- - Fixed issue: Boot to shell unable to map USB key if they are too many devices in the system.
- - Add: Display AGESA version for supported BIOS files.
- - Minor improvements.
- - Minor GUI update.
Updated UEFI flash-tool version to V1.41
- * Update: Extend AGESA support detection.
- * Add: Display Intel ME-FW version for supported BIOS files. [different bases in different colours]
- * Update: Optimize and speed-up detection for AGESA & Intel ME-FW
- * Update: Secondary flasher
- * Add: Add support for additional custom flash command for 256MBit Intel BIOSes
Updated UEFI flash-tool version to V1.43
- * Fix: Fixed issue unable to overwrite target if the read only flag has been set
- * Add: Add Intel ME-FW flash support for Z690 Series:
- MEG Z690 GODLIKE
MEG Z690 ACE
MEG Z690 UNIFY
MEG Z690 UNIFY-X
MEG Z690I UNIFY
MPG Z690 CARBON WIFI
MPG Z690 CARBON EK X
MPG Z690 FORCE WIFI
MPG Z690 EDGE WIFI
MPG Z690 EDGE WIFI DDR4
MAG Z690 TOMAHAWK WIFI
MAG Z690 TOMAHAWK WIFI DDR4
MAG Z690 TORPEDO
MAG Z690 TORPEDO EK X
MAG Z690M MORTAR WIFI
PRO Z690-A WIFI
PRO Z690-A
PRO Z690-A DDR4
PRO Z690-P WIFI
PRO Z690-P DDR4
Updated UEFI flash-tool version to V1.44
- * Optimize: ME-FW detection related to system info [not related to flash ME-FW detection]
- * Improve: Fix ME-FW 14.xx detection "not found" issue to specified class BIOSes [not related to flash ME-FW detection]
Updated UEFI flash-tool version to V1.45
- * Minor bug fixes
Updated UEFI flash-tool version to V1.46
- * Fixed rare issue: pressing enter multiple times while loading bios sometimes shows a new empty form.
- * Fixed issue: Browse for BIOS file appear at left side and dialog position always reset at next execution.
- * Improve USB BIOS guard handle.
- * Minor GUI update
- * Other minor internal optimizations.
- * Add: Add Intel ME-FW flash support for B660 & H670 Series:
- -MAG H670 TOMAHAWK WIFI DDR4
-MAG B660 TOMAHAWK WIFI
-MAG B660 TOMAHAWK WIFI DDR4
-MAG B660 TOMAHAWK EVA e-PROJECT
-MAG B660M MORTAR MAX WIFI DDR4
-MAG B660M MORTAR WIFI
-MAG B660M MORTAR
-MAG B660M MORTAR WIFI DDR4
- MAG B660M MORTAR DDR4
-MAG B660M BAZOOKA
- MAG B660M BAZOOKA DDR4
- PRO B660 - A
- PRO B660 - A DDR4
- PRO B660M - A WIFI
- PRO B660M - A WIFI DDR4
- PRO B660M - A
- PRO B660M - A DDR4
- PRO B660M - A CEC WIFI DDR4 V2
- PRO B660M - VC WIFI DDR4
- PRO B660M - P WIFI DDR4
- PRO B660M - P DDR4
- PRO B660M - G
- PRO B660M - G DDR4
- PRO B660M - B
- PRO B660M - B DDR4
- PRO B660M - E DDR4 -
- Updated UEFI flash-tool version to V1.47
- * Add: Display Tool's Intel ME-FW Flash Versions
- * Add: Visual indicators when supported BIOS file is loaded in compare to tool's FW Flash versions:
- - flashing orange if the BIOS ME-FW is lower that tool's FW flash version.
- - flashing green if the BIOS ME-FW is the same as tool's FW flash version.
- - flashing light blue if the BIOS ME-FW is higher than tool's FW flash version.
- * Update Intel ME-FW Flash image for Z790, Z690, B760, B660, H670 Series to 16.1.30.2361
- Updated UEFI flash-tool version to V1.48
- * Add flash Intel ME support for PRO Z790-A MAX WIFI.
- * Add flash support for MPG X570S CARBON MAX WIFI.
Updated UEFI flash-tool version to V1.49
- * Appy totally different .efi solution for the issue "too many bios file". [The issue should be totally solved now and no longer happens.]
- * Updated internal assembly modules.
- * Code refactoring and minor optimizations.
- * Add flash Intel ME support for newest released Z790 mainboards:
- -MEG Z790 GODLIKE MAX
-MEG Z790 ACE MAX
-MPG Z790 CARBON MAX WIFI
-MPG Z790 CARBON MAX WIFI II
-MPG Z790 CARBON WIFI II
-MPG Z790 EDGE MONSTER HUNTER EDITION
-MPG Z790 EDGE TI MAX WIFI
-MAG Z790 TOMAHAWK MAX WIFI
-Z790 PROJECT ZERO
-Z790 GAMING PLUS WIFI
-PRO Z790-P II
-PRO Z790-VC WIFI
Updated UEFI flash-tool version to V1.50
- * Updated and re-arranged GUI (including changes for more easy text reading).
- * Fixed some minor typos related to error messages.
- * Update Intel ME-FW Flash image for Z790, Z690, B760, B660, H670 Series to 16.1.32.2473
- * Add new feature: Display Raptor Lake-S B0 CPU's uCode version for supported BIOSes.
- Updated UEFI flash-tool version to V1.51
- Fixed bug in .efi module causing func callback's issue in some cases.
- Updated UEFI flash-tool version to V1.52:
- * Update .efi detections.
- * Update other assembly modules.
- Older version V1.33 and above can self-update to the latest one
- Updated UEFI flash-tool version to V1.53
- * Updated Intel ME-FW flasher for Raptor Lake supported boards.
- Updated UEFI flash-tool version to V1.54
- * Updated and patch the secondary flasher.
- * Improve async operations when preparing the USB key
- Updated UEFI flash-tool version to V1.56
- * Improve compatibility with msi's Corsair prebuilt units [thanks to 'fireboy7050159d02de' for reporting & testing]
- Updated UEFI flash-tool version to V1.57
- * Updated internal assembly modules /sys lang modules/
- * Updated replacer module (part of build-in self updater)
- * Add support for newest msi AMD BIOSes formats: 9.4
- * Updated .efi & shell script modules
- * Add support for newest MSI AMD platform boards:
- - X870 GAMING PLUS WIFI
- - MEG X870E GODLIKE
- - MAG X870 TOMAHAWK WIFI
- - PRO X870-P WIFI
- - MPG X870E CARBON WIFI
How to use:
Short guide for now:
Next reboot computer,
and ensure in BIOS Setup:
UEFI Boot is allowed,
and Secure Boot disabled.
i.e: choose to boot from:
UEFI USB your drive
when flashing starts,
wait patiently to finish,
efmled date=1563998092 said:I wanted to Thank you Svet very much! You saved many nerves to lot of people! Tool is great! I managed to downgrade my A.90 BIOS on X470 Gaming Plus MB to A.60. And I also created a video tutorial of how to do it. And put the link to this topic in video's description. if somebody is interesting in. Video has two languages text explanation Russian and English.
efmled date=1563998092 said:You can attach the link to your top message in this discussion theme.Thank you Again !
Here is the link to video:
[youtube]
