Forum USB flashing tool!!! ✔
lordxale
Well, I went for it with v1.14 of the tool (I also posted in that thread ). For reference again, this was a B350M Mortar Arctic, I had briefly installed the beta 7A37vAKS before in-place downgrading to 7A37vAI, then used the tool to force downgrade back to 7A37vAA and everything seems to be fine again.
Administrator
@ganepipopopi0159e02e3
Yes it can, but if you trying to flash between different BIOS core bases,
then you will need a special archive to able to do it.
Administrator
Yes it is, the pass is listed in the 1st post.
pylso156702e1
With this system you can correct a bad BIOS installation?
With this system you can correct a bad BIOS installation? I did an update and it didn't go well. the computer tries to start but cannot. The vendors turn on but after 2 seconds it turns off. I don't know how I can fix it anymore.
Administrator
The tool can't help with bios recovery if the computer can't boot.
pylso156702e1
Any suggestion? I am looking for solutions but cannot find. I have an MSI H81M-E33 board. I did an update and it didn't go well. How can I return to Update? I removed the stack, and it did not work. It tries to start but cannot. 2 seconds and turns off. I need help. Thanks in advance
Administrator
What you have flashed from which bios to which and how?
pylso156702e1
I have downloaded the latest update from the official MSI page, and I have done as in the video on the page. Now I have this problem and I don't know how to fix it.
deswr128502a8
I just want to add my thanks here to the people that put together and maintain this msi forum flasher , I used it tonight to restore my system , without you I would be dead in the water :dance:
Straussy
New here Hi to all just trying to get to the BIOSes downloads list but links seem to be broken
Cheers
