Forum USB flashing tool!!! ✔
Gimp the Imp Pimp
[Esquire]
Hi there.
I have a P67A-GD65(B3) with a i7-2600K@4.4GHz, 16GB@1600MHz in three sticks (4+8+4 configuration), and a RX580(4GB). Been running this configuration ROCK-SOLID with the beta BIOS 4.43 for 12 months, and for 6 years before that with the i7@4.3GHz, 8GB@1600MHz (4+4), and a HD6850(1GB). The extremely rare BSOD were mainly due to some USB/External HDD cock-up. Never had one while playing games (or rather, one HW related) or encoding H.264 videos, with CPU/RAM at 100%, for hours.
Yesterday, when I was (admittedly) doing things I shouldn't be doing (messing with the BCD settings of my dual-boot/dual-SSD PC, which locked me off both), during one of the reboots it made a couple of tries (like the ones when trying new OC parameters, although I wasn't changing anything in the BIOS except boot settings) and I couldn't get the screen to turn-on. Everything was spinning fine but no Windows, no USB drive and no BIOS/Setup. Only when I removed the case panel to start unplugging/removing/switching stuff and saw the steady blinking blue LED I realized what happened: primary BIOS failure.
What I didn't realized though was that "Blinking-Blue-Light-Primary-BIOS-Failure" doesn't mean "NO BIOS!!!".
To cut a very time-consuming, nerve-wrecking, story short: I had a working BIOS all along (that's the secondary BIOS), but because it was v1.18 it didn't, of course, know what a "RX580" is (nor what DisplayPort is either apparently, because even with the HD6850 only when I connect an old monitor through DVI, I got the screen to turn on).
As things stand I've already tried to update v.1.18 to v4.43 (twice) with the forum's tool but it returns "4 - Error: ROM file ROMID is not compatible with existing BIOS ROMID", and then re-flashes the backed-up one (v1.18).
I really would appreciate some help here. Thanx.
Gimp the Imp Pimp
[Esquire]
@gimptheimppim155e02db
You need special archive to able to reflash to a different BIOS bases [x.yy => z.yy]
You can follow those instructions with MSIHQ Tool:
Hi Svet, thanks for the reply and, above all, the effort put into this tool and forum.
I figured it out. I skipped a couple of lines of the guide, namely where it said I should use the zipped BIOS, without extracting it (I was really very tired).
Used the tool with option one, browse to THE STILL ZIPPED BIOS FILE (as downloaded), reboot, flash, shut-down, clear CMOS (per guide), power up, enter setup, confirm correct BIOS version (v4.4B3), load defaults, save&reboot and presto: SODDING BLUE LED STARTED SODDING BLINKING SODDING AGAIN!!!
Entered setup, realize it's still the 4.43 BIOS, and then it dawn on me "I must have flashed the secondary BIOS only". Looked for the "Multi BIOS Auto Update" setting, enabled it, saved, rebooted and crossed my fingers...
PXE ROM prompt, led still blinking, external SATA controller prompt, led still blinking, "Flashing BIOS: 0%", led stopped blinking. Waited to 100%, when it tried to auto-reboot I shut it down and cleared the CMOS, again. Power-up, no blinking, enter setup, 4.4B3, yay, hi5-me!!!
All seems to be working now, did a few reboot/shutdown cycles, no issues, 16GB back on, no issues. Removed iME7.1 drivers and installed the 8.1 ones, still no issues.
I believe I won't be getting a new PC for my bday after all.
Perhaps Christmas...
mrdeathscr151202d1
Hi everyone! I have managed to mess up my msi p67a-c45 b3 with a non "b3" bios and now it gets stuck at "A3" when booting, ive tried to move the HDD to different ports and leave it disconnected but still get the A3 error, what i have tried so far is to create a USB stick with the "Tool94" and the correct bios file for the b3 revision (done on a Asus motherboard) and at boot pressed ESC, F8, F11 but to no avail, when i pull out and put the USB stick (located in the top usb 2.0 port with a AMI bios sticker on it) it flashes for a second and then the error messages goes to B4 but then nothing. Am i missing any crucial steps here or is it time to order a external flasher? (There is a header right by the soldered bios chip)
msi p67a-c45 b3
i7 2600K
1 2gb stick of 1600mhz ram
low end graphics card
250gb Sata HDD
Thanks in advance for any anwsers!
Administrator
Nope, it won't work for uefi boot flashing
robby.tranc12e402b7
Hi Svet.
I have a similar problem like another one earlier, with a P67S-C43 (B3) . I get the same error with the ROMID using both 5.1 and 5.4 version. What should I do? :(
LE: I've found your zipped version for 7673v54 and used it with tool94 and it worked! Thank you in advance :)
Administrator
if you are flashing from different base ID like 1.xx to 5.xx then you need a special archive to make it works
well done
Hi, I get the error "Online server cannot be reachable" error while using the tool. It seems that it tries to download Memtest online, but it fails. Does anyone get the same error? And If I download Memtest and put the .exe file to my USB, would it fix it?
Administrator
Use the latest tool version.
Administrator
Update: Saw the issue, been updated to tool96
dvminh151602cd
Dear Svet
Can I use this tool for MSI GT80 (https://www.msi.com/Laptop/gt80-2qd-titan-sli/support)?
My laptop got a problem with the intel management interface, and the light bar does not turn on; I cannot switch between VGAs. I tried to use the UEFI update in the current bios, but it does not work. The laptop just blinks three times and does not update the new bios. I have spent several days on these.
If the tool does not work with GT80, can I flash my laptop with DOS tools?
Thank you for your help!
Administrator
Nope, its not intended for those units.
Coven
Hello, I am using the MSI B350M PRO-VD PLUS model. I've updated my motherboard to the latest BIOS version and it's a Beta BIOS. Since I had some problems with this version, I tried to revert to the previous non-Beta stable version. But I can't downgrade the BIOS version. I would be grateful if you could help me with this.
Administrator
There is no 32bit version, it's been abandoned from long time.
You can prepare the USB key in another PC for that board within Windows,[a normal 64bit PC I assume]
when the USB key preparation is done, then you can move it and plug it on that PC [pm8m3-v] to proceed with flashing.
edlmeta151402ce
Hi there! I'm having trouble with the new BIOS beta version of the A320M PRO-VH PLUS motherboard, so I wanted to downgrade to a stable version but I'm not having luck. I already tried the tool96 way but It doesn't work. Any suggestions?
Thanks!
