Forum USB flashing tool!!!
richard.fay
I just want to double check to make absolutely sure: on the OP, with the download, it says "Attached files are visible to logged-in users," but I am logged in and no new attachment has shown up. Below that is a mediafire link called INdeb. Should I be downloading the INdeb file, or is the file attached to the OP and I can't see it for some reason?
Stupid question I'm sure, but I'd appreciate any help!
Administrator
yes the link is fine, its no longer attached after version update
because forum server don't provide enough space for file attachment anymore
rhettbohling
I am trying install ubuntu. I cannot install until I update BIOS firmware. I cannot seem to update BIOS.
How do I get around this?
Board: MSI A78M-E45 V2
VGA: MSI GEFORCE GT710
CPU: AMD Athlon(tm) X4 750k Quad Core
MEM: 2x8GB, HyperX
OS: None at this time
BIOS Version: E7721AMS V5.0
Please open your own thread in AMD motherboard section. Your question is not directly related to the forum tool.
asteroide404
Hi everyone !
I have an MSI Z77a GD65
I have succesfully find the last bios version from MSI HQ Forum and do the preparation of the USB key with success !
I can boot from the USB key
But when i launch the flash from the DOS menu of the USB key
this message in blue appears :
"You are not authorized to perform this action"
And then, the screen of the end of flashing (i suppose) appears...
How can i get the authorization to perform this action please ?
Administrator
@asteroide404
I've updated the version,
re-download new one, and try again
anders_olsson_91
Hi!
I've been trying to update my BIOS.
I have a msi Z87-G45 Gaming motherboard and have downloaded the 1.8 version (1.9's file seems broken) from:
https://www.msi.com/Motherboard/support/z87-g45-gaming
My current BIOS version is 1.2
I've set my BIOS to [Legacy + UEFI] (only have option for UEFI or both), fixed my USB with the tool, used the tool to get the files on it but it still boots normally after I choose to boot from the USB after I've pressed F11 (Tried both with the one named "UEFI:"at the start and the one without), only difference is that before the Windows logo there's a black screen with a blinking underscore and than after Windows loads it opens the USB to see the files.
Administrator
andols91 date=1553694790 said:
Hi!
I see the flasher is missing for 1.9,
you can use Mode2 to flash it in such case
Have you done "Fix My USB key" tool's option 1st?
anders_olsson_91
Okay, I'll add that instead of 1,8 then.
I have done the "Fix My USB Key" option before adding the file with 1,8 to the USB. Would it make any difference to use the "HP USB Boot Utility" instead?
Administrator
use this then, pickup Rufus:
https://rufus.ie
and make it bootable with "FreeDOS"
then re-run the tool but skip fix my usb key
go directly with mode1 and rest of stuffs
Administrator
@hardi.hama12
open new own topic in correct area
eloyhbermudez
hello !!
i am trying to flash my current gt60 2pe,  i use the option to point out the zip file but i get error 312, after that i get the prompt to use the option to point out the specific bios file , but when i go into menu i dont see that as an option just to use the zip file . any help to fix ths will be appreciated
Administrator
eloyhbermudez date=1568772338 said:
hello !!
you have to follow those instructions instead:
http://www.msi.com/files/pdf/How_to_update_bios_en.pdf
jameskacc3
The forum HQ USB Flashing tool requires a password? Am I missing something or has the file been locked?
yeah... :rtfm:
Also don't use moderator reports if you have a question.
Svet date=1178268764 said:
The download links are listed below:
:lookandok:
attached files are visible for logged-in users.
https://www.dropbox.com/s/pdx6pgnsqvdgmjh/tool93.rar?dl=0
pass: 1562
positivereflect
went to update my msi h61ma e35 to latest bios.....and when using the bios download from the boards support section (v230) it froze after starting the update.
nothing would make it respond, and i knew when i turned power off it would be a no post situation...which it was.
so dug out my old bios flasher and flashed a chip to v120 and then fitted it in my spi header adapter, got the board reflashed to v120 but intel me was messed up/.
then i found this part of the forum and using the tool to do the usb stick formatting and then mode 1 selection, i now have it on latest beta v241, and intel me now ok :)
many thanks for this handy tool :))
eddiepinkyp
Hi there,,,i'm new to this forum....i downloaded the tool..but when i tried to open it to put it on usb pen it said it was password protected....any ideas please...and how do i get my txt here to go on all page...not just corner...cheers....Eddie
