Forum USB flashing tool!!!
Chike
GENERAL
eddiepinkyp said:
Hi there,,,i'm new to this forum....i downloaded the tool..but when i tried to open it to put it on usb pen it said it was password protected....any ideas please...
Svet date=1178268764 said:
ass: 1562
Chike
GENERAL
Password is there just below the download link
minkawilson
PRIVATE FIRST CLASS
Hi, I have a gt72 2qd dominator, 5th gen that I am trying to flash but it says to unzip and use mode 2, but there is no mode 2 on the tool.
I am running windows 10, 64gb.
Thanks for your help
Active member
Administrator
mode 2 is disabled for notebooks
see here how to flash your notebook:
http://www.msi.com/files/pdf/How_to_update_bios_en.pdf
minkawilson
PRIVATE FIRST CLASS
Thanks, but it wont go to step 13, I have tried 3 or 4 times
Active member
Administrator
minkawilson date=1573362284 said:
Thanks, but it wont go to step 13, it just restarts.
I have tried it 3 or 4 times.
what step 13 :think:
where you see this?
minkawilson
PRIVATE FIRST CLASS
It wont go to
:13 proceed with flash update.
It wont enter BIOS setup utility.
It restarts but goes to my normal login to windows
Sorry couldn't insert image.
Cheers
matthijs.steen
i can for the life of me not download the flashtool. someone plz help. this rararchive has no password specified
matthijs.steen
I am trying to download the flashtool. but when i want to extract it its says: has no password specified. I have tried it a month ago before and had the same issue. i now have a rtx2060super that needs the new nbios but i can not get the tool.
Chike
GENERAL
The password is just under the link
matthijs.steen
thanks for your reply. I have seen the password but the download or extract doesnt give me the option to insert a pasword. it only says error and "nopassword specified"    rar files are supported but something went wrong.
EDIT i changed my rar extratc psoftware from 9zip to winzip and this solved the problem
Chike
GENERAL
It's for opening/extracting, no problem with 7-zip, what software are you using to extract?
Active member
Administrator
see his edit, some 9zip [which personally i never hear until now]
Chike
GENERAL
That's what you get when you shop at microsoft store.
cryptomadness1948
I tried to create a bootable USB to downgrade my BIOS, but I am getting BSOD on both machines that I tried using two different flash drives.
I installed net framework 2 and 3 after the first BSOD and the next time it did some additional tasks before crashing again. Problem occurs while creating the image.
Any idea what critical piece of software is missing ? I'm using Win 10, fully updated.
cryptomadness1948
OK, I made that work. Created the flash , booted into it ... performed the procedure. It said that update is complete , rebooted ... and nothing had actually changed. I have read that I may have to make sure that the bios is not "protected" or something, but I don't really see such option in the BIOS.
Its a MSI Click BIOS (the grey version). E7B85AMS.1B0
The bios in the flash that I wanted to put there is a E7B85AMS.140
Can you help me get there? What exactly do I need to change in the BIOS so that flash works?
Active member
Administrator
@cryptomadness1948
What mainboard you have?
and which mode and which file you used to prepare the USB key with the tool?
