Forum USB flashing tool!!!
pmax69
Hi guys!
I'm new on this forum and I have to update my  msi z77-a g43 bios for the reason that  it won't boot with  a new vga  rx580, and here I understood this is the solution.
Please tell me , the link of this USB tool from  the first page of this thread is up to date ,or I should look for a new version in the thread?
Thanks and  happy holidays !
Administrator
pmax69 date=1577202256 said:
Hi guys!
It's up to date.
Happy Holidays
chawndraroyal80
Ok I tried to use this tool but it said it cannot find the path specified. What do I do? I updated the wrong Bios and cannot fix and I keep getting the blue screen of death.​
yohan.gissinger
PRIVATE FIRST CLASS
Can I prepare the USB key with an other computer in order to flash my computer ?
Because my computer is blocked on :
[font=DINCondMediumRegular bebas_neue_cyrillicregular BebasNeueTurkishSubset BebasNeuePolishSubset sans-serif]"Warning!! BIOS ME update....file not found."[/font]
mertcanozcirpan
PRIVATE FIRST CLASS
hello
i try to downgrade my z68a gd55 bios to 23.8. ? used 3570k but now ?m using 2600k but its unstable with latest bios.
i download this tool and try to downgrade but it gives me this error. there is a failure but i dont understand why.
could you please help me?
thanks guys
https://www.imageupload.net/image/xDIBk
mertcanozcirpan
PRIVATE FIRST CLASS
Hello again. I find a command path in this forum but when i try to use it it gives that warning. ? stopped when this warning came to me. I know this bios is for this mobo. But its earlier version. Thats why giving this problem, right;
https://www.imageupload.net/image/bios-2.x5fUt
Thanks.
Sorry for bad english :)
Administrator
Thanks.
no, do not try to flash in that way it can brick it.
abort flashing
mertcanozcirpan said:
Hello again. I find a command path in this forum but when i try to use it it gives that warning. ? stopped when this warning came to me. I know this bios is for this mobo. But its earlier version. Thats why giving this problem, right; https://www.imageupload.net/image/bios-2.x5fUt Thanks. Sorry for bad english :)
it need a special prepared archive to able to flash it
will find it and update you
Administrator
Update:
use this special archive with valcheck.com and .N88 with Mode1
https://forum-en.msi.com/index.php?action=dlattach;topic=163866.0;attach=10855
mertcanozcirpan
PRIVATE FIRST CLASS
Svet date=1587399954 said:
Update:
Thank you for your response and efford :hypocrite:
But i dont understand the valcheck and .N88 with Mode1 part, could you please explain it more softly ;D
Administrator
just use Mode 1 from the tool and point to the .zip/.rar file that I linked you
then follow the same steps as before
mertcanozcirpan
PRIVATE FIRST CLASS
i boot the bios with the last one you gave to me, pc didint boot. Just black screen with flashing line. I cleared cmos and go to bios but here is so messy. i select mainboard setting and everything just get inside and i cant select my windows boot.
what should i do right now?
tnx
Administrator
you mean you can't flash the bios or you already flash it?
mertcanozcirpan
PRIVATE FIRST CLASS
no i flashed it but windows didint boot.  When i clear cmos i can enter the bios menu but its broken. I cant select boot device. When i select a menu it look like this:
https://www.imageupload.net/image/x9gTb
? boot the same bios again, same problem again. Could you gave me another 23.x bios link? Maybe its from this versions problem.
Administrator
Is this B3 revision or G3?
and do you a use monitor or TV?
Administrator
Got it, then what you flashed is the correct and latest 23.xx bios as you wanted.
mertcanozcirpan
PRIVATE FIRST CLASS
what should i do right now? boot a lower version of that could be solution for me maybe?
https://www.msi.com/Motherboard/support/Z68AGD55_G3
can i use lower than this version? maybe i'll try 23.6 maybe it will work
Administrator
best open new own topic in correct area for trouble shooting
https://forum-en.msi.com/index.php?board=54.0
don't know depends what are current issues
and what bios's bugs will have other bioses
but if the latest 23.8x has such, then probably lower also will have it
you should also check if the lower can support your CPU used,
else may unable to boot at one if you flash to BIOS that do not support your CPU
either try to troubleshoot it or flash back to 25.xx versions
