G27C2 Green and Black Line Flickering Problem
aaron1740157502e0
I recently bought this monitor from a friend of mine and whenever I turn it on the picture gets glitchy and starts showing green and black lines and goes away after a little.
It seems like at 120hz it glitchy slightly but goes away and when I switch to 144hz the lines are everywhere for a while then goes away.
I have made sure it wasn't my display port or HDMI and it's definitely a hardware problem 100%.
Does anyone have a fix for this cause it's not a huge problem waiting for it to "warm up" but a solution would be much appreciated.
jcnavarr157402de
I have the same problem, doubting if is the GPU, but I changed to another computer and works ok. I replaced with older GPU and works fine. connected to a laptop and works fine. Maybe is the resolution o the htz ????
How did you solve it?
Sent to msi warranty?
