Did anybody get wincoder and winproduer bundled with this card if so why won`t wincoder load in.It`s not given as an option on the load screen and if you try and load it manually the serial key is not accepted.
Are you sure you entered the Key 100% Correct? If you have, you can contact MSI to verify the Key should it not work. I have had this problem with other companies and I have either contacted the hardware maker or software company and been issued a new code over the phone.
Did you get two icons on your desk top one for wincoder and one for winproducer.Is it me being thick and wincoder is within winproducer.When you first installed it from the cd did it list the two program for install because it only gave me the option to install winproducer even though wincoder is on the disk.
I ran demo32 from within autorun folder. From there you install software. Two icons on screen when done.
If this dosn't work do as Deathstalker said and contact MSI to verify key.
The key on my cd is hard to read. You could swap O and zero around
I uninstalled it and reinstalled it and it installed winproducer then to my great suprise told me it was installing winencoder.So alls fine now I don`t know why but it is. .
Thanks all for your help.
ps I did contact msi and the were very helpful and quick to responded within the hour twice.
