hsynnam159f02e5
- Jan 15, 2026
After enabling Game Boost, if I clear CMOS using the rear motherboard button (only after shutting the PC down), can this cause any problems? Can it directly damage any hardware component, or cause things like a drop in %1 low FPS?
What Game Boost does is basically set the PBO limits to “Motherboard,” set the scaler to 10×, and apply a Curve Optimizer value of –5.
How harmful is clearing CMOS after using Game Boost? What are the possible symptoms? Can it directly affect %1 low FPS?
Even if I later set everything back to the correct values like 6000 MHz CL30, could this still cause %1 low FPS issues or any other kind of lasting damage?
I couldn’t find much clear information about this. I would really appreciate your help.
System:
Ryzen 9800X3D – MSI B850 Tomahawk MAX WiFi
System:
