GC300 W can't connect wireless after firmware update
I just updated the control through MSI Center, but now if I try to connect with wireless connection, the power LED is only flashing white. It seems that can't connect withthe dongle.
The dongle is pluggled, and I already tried to plug it in other USB ports but nothing changed.
The cable connection and the Bluetooth pairing are working.
Win11 64, MSI X870E.
Any suggestion?
Can you try hold the reset button for 5 seconds?
Hi plutomate,
thaks for your answer.
I tried with the reset button, but no changes.
I tired even to manually update the firmware with the driver from msi.com, but still it doesn't connect.
Other suggestion?
I'm having the same problem with my controller . When i use the cable it works , it opens gaming gear menu and show firmware version 1.56. But when i used the wireless dongle it said i needed an firmware update from msi center. It wasn't possible to update it through msi center because it was stuck on updating. Contacted support and they said to do it from the site. I did the wireless dongle update and now the device doesn't connect. Contacted support and rn im waiting. When i plug the dongle on device manager it shows as usb billboard device. Did cross testing on another pc ( still not working ) , tried reset for 5 second and etc. I'm waiting for a respond on my ticket . Hope it get's resolved .
I'm having the same issue as previously expressed. To give a more detailed history, i downloaded the latest FORCE GC300 WIRELESS firmware updaters for both controller and dongle (version 0.4). Firstly ran the controler updater following the instructions (i.e. download-2.msi.com/archive/frm_exe/gear/FORCE-GC300-FW-Upgrade-SOP-EN.pdf), the update was successfull. Secondly i ran the dongle updater, inserted the dongle, on pressing the dragon button the controller successfully connected (green light), and i followed the next steps, one point of note: i let the Erase Flash still Enabled, clicked start update button, waited and success. After this i can't connect my controller through my dongle. Re-instaling the dongle firmware is not an option, since connection to the dongle is required. Could the Erase Flash option have caused this problem? What should be my steps to solve this issue?
Best regards
Does the LED keep flashing white while dongle is connected?
Try to long press the Dragon Button for 3 seconds and it should start re-pairing the dongle and the LED should flash white rapidly.
Usually it would take a few seconds to re-pair the dongle, and the LED will change to solid white then green.
