- Dec 23, 2015
Hi, this notebook is thin and sturdy. The material quality is good. However, the notebook can get a little hot while playing. The reason for this warming is fine. Overall performance is good. It's portable. Scratch and sound quality is good. The keyboard has a good illumination. Charge adapter, documents and mouse come out of the box.
Windows 10 Home / Windows 10 Pro
Latest 6th Gen. Intel? Core? i7 processor
GeForce? GTX 970M graphics with higher performance
17.3" TRUE FIREPOWER
NVMe M.2 SSD by PCIe Gen3 X4 up to 2200MB/s speed(optional)
The latest USB 3.1 SuperSpeed+ interface built in
USB Type-C reversible plug
Exclusive SHIFT technology boosts performance under controlled noise & temperature
Exclusive Cooler Boost 3 Technology
Nahimic Sound Technology delivering 360? immersive audio experience
Audio Boost 2 enhancing the gaming headset sound detail and sound stage
Sound by Dynaudio system
True Color Technology for increased color contrast and greater image detail
SteelSeries Engine 3 with GameSense to personalize your play style
Keyboard by Steelseries with full color backlighting
Upgraded Killer Gigabit LAN Controller + Killer Shield + 802.11 ac
Xsplit Gamcaster 1 year free premium license for broadcasting, recording and sharing
Matrix Display supporting 4K output up to 2 external monitors
Elegant brushed aluminum chassis, creating an ideal fusion of aesthetics and performance
Experience a whole new way to interact with your PC like never before. With the power to understand your motions, recognize your face and respond to your voice, 6th generation Intel Core H series processors take computing to the next level. They require lower power consumption but deliver better performance than before. CPU performance of Core i7-6700HQ is 20% faster than i7-4720HQ under average usage.
?SHIFT? ? BOOST PERFORMANCE UNDER CONTROLLED NOISE & TEMPERATURE
The exclusive MSI ?SHIFT? technology pushes system to the extreme while minimizing noise and temperature. Switch between three profiles ?Sport,? ?Comfort,? and ?Green? to reach balance between system performance and comfortable user experience
LATEST ARCHITECTURE DDR4-2133 MEMORY SUPPORT
Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving over 29GB/s in reading speed and 32GB/s in writing. With over 30% faster performance than previous generations DDR3-1600, DDR4-2133 is the new laptop standard to take your extreme gaming experience to the next level.
COOLER BOOST 3: KEEP CALM UNDER PRESSURE
Heat is the most original element on earth. It?s pure physics that more energy will generate more heat. Cooling is therefore a knotty task to tackle with. MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system.
TRUE COLOR TECHNOLOGY
MSI True Color Technology guarantees that each panel in a MSI notebook comes with the finest precision in color. After examination and an extensive factory calibration process by the MSI True Color Technology, the panel quality will be more accurate, close to 100% sRGB. Hence, each color is delivered with the highest standard precision in detail, guaranteeing excellent color fidelity for many use applications.
MSI has partnered with Portrait Displays, Inc. in developing a level of accuracy for display technology that sets a new standard. Trusting that the displays colors naturally represent the content is MSI?s objective.
TRUE COLOR PROFILE
Vision and sound are the most important two factors in this field. You now get to see clearer than your enemies to always get one step ahead of the rest. Besides Gaming Mode, True Color Technology also offers prefect color accuracy for 5 more scenarios. Work or play, you can easily switch to the mode that best suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere.
TRUE COLOR PROFILE
