[GE72 7RE APACHE PRO] Full access to NVIDIA control panel
lutxoz153702d2
I'm using a GE72 7RE APACHE PRO, I want to have full access to the Nvidia control panel and I cannot since it connects through the integrated graphics card instead of the dedicated card.
So when I open the Nvidia control panel, there is no "Display tab". Some laptops have MUX in the BIOS, also, I've found that some MSI laptops can do the same using the MSI center, but I cannot because the laptop isn't included in the list of devices.
Can someone help me out?
Thank you in advance.
You must use Intel Control Center or what's it called to control settings which are not on Nvidia Control Panel.
Hope this helps.
1. Steps to Set the Preferred Graphics Card
NVIDIA Control Panel - Manage 3D Settings - Select Preferred Graphics Processor - Apply Changes
Under the Global Settings tab, find the dropdown menu labeled Preferred graphics processor. Here, you can select High-performance NVIDIA processor to make it the default for all applications.
2. Setting Preferences for Individual Applications
If you want to set the NVIDIA graphics card for specific applications rather than globally, follow these steps:
NVIDIA Control Panel - Manage 3D Settings -Switch to Program Settings tab - Add Application - Choose Preferred Graphics Processor - Apply Changes
Thank you, I didn't thought about the integrated graphics controller software.
Sadly I've found that the custom resolution configuration for an external monitor is no longer possible with Intel Graphics Command Center, which is what I need right now. So I've used external software for this matter (Custom Resolution Utility).
I'd prefer to use Intel software, but I can't find a way to do that :/.
Hope this helps.
Not helpful, but thanks for the answer anyway.
