It will work but you will wan to upgrade the PSU minimum is 700 wattsSI GeForce RTX™ 4070 Ti SUPER 16G VENTUS 3X OC
thanks for the reply. I will upgrade the power supply.It will work but you will wan to upgrade the PSU minimum is 700
I second this. If you cheap out, you're more likely to spend more money in the long run if it fries the components it's plugged into.Also make sure to choose a quality and reliable PSU. Not just some generic or cheap PSU.
