GaiusEmil
GaiusEmil
- Nov 15, 2021
This GPU is a BEAST!!!
I have never seen better cooling cababilities in any other graphics card. Card has never gone over 60 Celsius when gaming overclocked. Most games graphics maxed out. Most games stay at 50 C or less.
Completely silent. Haven't heard any noise at all from it(my computer is right next to me at my desk).
GPU has good default fan curve. Had to make only small adjustments.
Gpu is very heavy and big. Weights 1477 g and is 323 x 140 x 56 mm. You REALLY do need a big case for this. My case is 415 x 215 x 460(Kolink Stronghold Overseer) and the gpu barely fits in. 2 cm more and it would hit the front fans of my case.
Overclocking is very easy. Boost clock is1852 MHz, but I run my own at 2025 MHz. Doesn't raise temps much and boosts game performance.
Very nice RGB lighting. Easy to control with Mystic Light.
Comes with a bundled support bracket (high quality, easy to install, very good looking)
Requires two 8 pin power connectors, but the power consumption is very reasonable 170W
I really recommend it for everyone!!!
