V
viper
Guest
Re-formatted with WIN98 SE, downloaded latest driver
'detonator XP version 29.42, running 256 ram PII 500.
- before re-format card ran fine. Now it has weird glitches while playing the game; " Morrowind- elder scrolls III " [also with other games]. It seems to be losing pixels or creating blank lines shooting through the graphic even if I am not touching the key board or mouse. It never did this previous to the re-format and clean install. Is there something I should change in the cards 'properties', maybe under 'additional properties'?
It is frustrating to not correct this. I have the latest BIOS
update for my ABIT-BH6 motherboard. Can not find video driver in Archives for my card...' M8815PRO ' only for the 'M8815' 32MB card.
Display Adapter information shows :BIOS version 3.15.00.12, GeForce2 GTS, 64MB memory.
-Does it matter what BIOS version I am running?
-Would there be a conflict with the drivers I installed for my Viewsonic monitor?
I have been told to remove my RAM and reinstall it, first the 128mb, then see if that corrects the problem, then install the other 128mb and see if that still corrects the problem. I was also told to interchange them around from their original positions that I had them in before the re-format.
Anybody know? . . . thanks
