jameschrst2714f502ca
- Nov 10, 2024
Got this build https://pcpartpicker.com/list/n4Fp9C working yesterday, didn't notice any issues with it besides the WIFI adapter not being found in the device manager, though I managed to connect to the wireless anyway by using my phone with USB tethering. Before long, an MSI menu appeared, listing all the drivers I had to install, which included the WIFI adapter. At a point, a notification popped up saying that I'd need to restart, and not long after that, my PC suddenly switched off. After this, I couldn't get it back on, with the Red + Yellow light on the motherboard, denoting a failure in the CPU and VRAM - though after everything I've checked, I'm not sure they're even related to the actual issue. Here's everything I've tried so far:
- Removing the Video Card and one Ram stick, leaving only the remaining one in the second slot, and switching on that way.
- Checking all the plugs in the PSU, unplugging and replugging.
- Leaving the computer on, with everything on, for about twenty minutes. The lights stay on, nothing happens on the display.
- BIOS flashes. Lots of BIOS flashes.
- Shorting JBAT1 for 15+ seconds (with the power cable disconnected, which didn't sound right, but whatever.). Did this three times.
- Reconnecting the Windows 11 USB stick, trying to switch on that way.
- Downloading the BIOS drivers onto a separate stick, and putting that in. Nope, I didn't have much faith in that.
- Removing the CPU cooler fans, looking for physical damage around that area. Nothing.
What I haven't tried
- Removing the CMOS battery. After at least three hours trying, I've given up. I've seen videos of others doing this easily, yet I couldn't, not without putting in way too much physical force. The contact looks fine, it just doesn't seem to work. Shorting JBAT1 is supposed to have the same effect, and that didn't do anything - though there's also no feedback to prove that I even successfully did that
- Reattaching the CPU. This seems like a total pain, and it *was* working fine. I don't want to risk damaging it, and doing this is somewhat of a last resort for me, not having a particularly steady hand.
If there's anything I'm missing short of disassembling the entire machine and starting again from scratch, I'd love to hear it.
As an additional note, my phone (plugged in to a usb slot) was restarted when the computer suddenly switched off, so for a time I was assuming a short circuit had occurred, and caused my phone to switch off. I'm unsure if that means anything.
