gf4 mx 460 tv-out problem
L
luishen
Guest
Help me please!! ?(
I've just upgraded my video card to a MSI Geforce4 MX 460 and spent my weekend trying to put its tv-out feature to work and failed (tv-out worked fine in my former Geforce 4 MX 440 from XFX using nvidia latest driver). I downloaded the latest version from MSI, but nothing happened, even following the manual step by step (it worked though with TV-Tool 6.5, a shareware available in the Internet).
Please, tell me how to put the card to work using its own properties and only the software provided by MSI for Tv-out. In my country (Brazil), the color system used is PAL-M, but my TV set is a Sony trinitron (model KV-29T80) that supports PAL-M, PAL-N and NTSC. I'm using S-video to connect the TV.
I heard somebody saying an older driver worked for the model MX 440. Will it work for the 460 too?
Thank you,
Luis
I don't have an MSI video card, but have you tried nView (from Display panel, Advanced), with the TV connected and switched to AV mode, clone mode from nView, second display selected and from properties PAL-M?
Thanks a lot for the hints.
As for the nview, I guess there's nothing I haven't done. Regarding the drivers mentioned, could you point to where are they? I've searched MSI and nvidia sites and haven't found them. Do they work in win2k?
My configuration is:
****************System Information****************
[MSI_Info]
OS Version: Win2K
LUS Version: 3.30.000
Language: 1046
MB Model Name: MS-1009
MB BIOS Vendor: Award
MB BIOS Version: Unknown
VGA Model Name: MS-8867
VGA BIOS Version: 4.17.00.30.06
VGA Driver Version: 3000
[OS]
Name: Microsoft Windows 2000 Professional|C:\WINDOWS|\Device\Harddisk0\Partition1
Manufacturer: Microsoft Corporation
Version: 5.0.2195
CSD Version: Service Pack 2
Windows Directory: C:\WINDOWS
Boot Device: \Device\Harddisk0\Partition1
Total Virtual Memory: 650 MB
Free Virtual Memory: 419 MB
Total Visible Memory: 192 MB
Free Physical Memory: 72 MB
Serial Number: 52594-005-6639281-09020
Install Date: 06/02/2002
Current Time Zone: Greenland , Georgetown
Locale: 0416
State: OK
[System]
Description: AT/AT COMPATIBLE
Number Of Processors: 1
Total Physical Memory: 192 MB
System Type: X86-based PC
System Wake Up Type: Other
Power Supply State: 2
Power Manage. Support: null
Bootup State: Normal
[BIOS]
Name: Default System BIOS
Manufacturer: Award Software, Inc.
Version: Award Modular BIOS v4.51PG
Serial Number: SYS-1234567890
Release Date: 05/10/1999
Target Operat System: Unknown
Language: ENGLISH
State: OK
[CPU]
Name: Processador Intel Pentium III
Description: x86 Family 6 Model 7 Stepping 3
Manufacturer: GenuineIntel
Processor Type: Central Processor
Version: Modelo 7, N?vel 3
Data Width: 32 Bits
Socket Designation: SLOT 1
Processor Id: 0387F9FF00000673
Processor Family: Pentium III
Processor Stepping: 3
Max Clock Speed: 500 MHz
Current Clock Speed: 450 MHz
Current Voltage: 2.9 V
External Clock: 100 MHz
L2 Cache Size: 512 Kb
Availability: Running/Full Power
Power Manage. Support: false
State: OK
[Memory]
Memory Device Locator: DIMM1-1
Memory Bank Label: RAS 1 & 0
Memory Capacity: 64 MB
Memory Total Width: null Bits
Memory Data Width: null Bits
Memory Type: Unknown
Memory Device Locator: DIMM1-2
Memory Device Locator: DIMM2-1
Memory Bank Label: RAS 3 & 2
[Mainboard]
Manufacturer: ASUSTeK Computer INC.
Product Name: P2-99
Version: REV 1.xx
Serial Number: MB-1234567890
[Sound Device]
Name: Unimodem Half-Duplex Audio Device
Product Name: Unimodem Half-Duplex Audio Device
Availability: undefined
State: OK
Name: Creative Sound Blaster PCI128 (WDM)
Manufacturer: Creative Technology Ltd.
Product Name: Creative Sound Blaster PCI128 (WDM)
State: OK
[Network Adapter]
Name: RAS Async Adapter
Manufacturer: null
Product Name: RAS Async Adapter
State: null
Name: WAN Miniport (L2TP)
Product Name: WAN Miniport (L2TP)
State: null
Name: WAN Miniport (PPTP)
Product Name: WAN Miniport (PPTP)
State: null
Product Name: Paralelo direto
State: null
Name: Miniporta de rede remota (IP)
Product Name: Miniporta de rede remota (IP)
State: null
Name: 3Com EtherLink 10/100 PCI For Complete PC Management NIC (3C905C-TX)
Manufacturer: 3Com
Product Name: 3Com EtherLink 10/100 PCI For Complete PC Management NIC (3C905C-TX)
State: null
Name: Wan Miniport (Network Monitor)
Product Name: Wan Miniport (Network Monitor)
State: null
Name: McAfee Firewall Network Filter Miniport
Manufacturer: Network Associates, Inc.
Product Name: McAfee Firewall Network Filter Miniport
State: null
State: null
[Video Controller]
Name: MSI MS-StarForce GeForce4 MX 460 (NVIDIA GeForce4 MX 460)
Current Refresh Rate: 60 Hz
Installed Drivers: nv4_disp.dll
Driver Version: 6.13.10.3000
Inf File name: oem12.inf
Monochrome: false
State: OK
[Video Configuration]
Name: Current Video Configuration
Monitor Manufacturer: null
Monitor Type: null
Horizontal Resolution: 800
Vertical Resolution: 600
Screen Height: 240
Screen Width: 320
