GF65 Disassemble cooling system
undersk156d02da
Hello everyone !
I was trying to disassemble my cooling system to set a new thermal paste but it is like "locked". After removing all the screws, it is always impossible to unleash it.
I cannot find any videos where they disassemble this part.
Can any of you help me ? :)
RaiderGamer
MAJOR GENERAL
if you truly have every screw removed then just pull harder. because it sticks
it should all come up / off as one piece, so prepare for that
badboy2k
wiggle it a bit off on the end with the single heat pipe as there is alot of thermal Pads and do the same for the rest of the cooler too around the CPU and GPU as you will have Hydraulic suction that is holding the cold plates against the GPU and CPU.
