GF65 Thin 10UE High temperatures when gaming (90+) and even when using Microsoft edge (65+).
nickleesp15a402e0
Like I stated above, I am getting very unusual temperatures for gaming and for basic use. The issues first came about when I noticed my frames dropped in apex from 144 fps to barley hitting 70-80 fps, game was performing bad as well.
I thought it was the thermal paste as it was coming up to a year so I got that changed and then factory reset for good measure as well.
I don't know what else I can do... it's coming up to 24 months old so I'm very confused to why this would be happening. Most of my gaming was done on an external monitor but due to traveling I am now using the laptop screen.
Any thoughts on what it could be or what I could try?
Below are my system details:
Serial Number: 9S716W212014ZL4000021 / K2103N0150091
Product Name: GF65 Thin 10UE
OS: Microsoft Windows 10 Home 64-bit Ver.2009(OS build 19044.2006)
HDI Build: ZS7-16W2RM4-XS1 / 12.1.I4.2.0.7
BIOS Version: E16W2IMS.103
BIOS Release Date: 2021/01/08
EC Version: 16W2EMS1.1011215202016:44:32
CPU: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
Memory: 16 GB @ 1466 MHz
- 8192 MB, DDR4-2933, Samsung M471A1K43EB1-CWE
Graphics: NVIDIA GeForce RTX 3060 Laptop GPU, 6144 MB
Graphics: Intel(R) UHD Graphics, 1024 MB
VBIOS Version: 94.06.13.00.91
Drive: SSD, KINGSTON OM8PCP31024F-AI1, 953.87 GB
Network: Realtek PCIe GbE Family Controller
Network: Intel(R) Wi-Fi 6 AX201 160MHz
Win32 SHIFT mode: Unsupportive
Power Plan: Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e (Balanced)
UWP User Scenario: User, Performance: Hight, Fan: Advanced
Graphic Switch: Unsupportive
drek4
PRIVATE FIRST CLASS
Well I try to reduce background apps that I don't need, I also disable windows update for 4 weeks.
I use ThrottleStop and with one click I can change to GAMING, INTERNET or BATTERY.
I reduce the Mhz 200-300 Mhz for each CPU latop in GAMING, 600-800 Mhz in INTERNET and DISABLE TURBO in BATTERY.
I reduce my laptop PL1 and PL2 values in the BIOS to what is required per say the Gen I'm using, they all come set much to high for the CPU.
(My P65 was set PL1 @ 55w and PL2 75w...Insane to say the least for a 9th Gen)
I always use COOLER BOOST when gaming, but if ever I game late at night, I put it to INTERNET and lower resolutions, with fan curve 10-40-70-110-140-150%.
If you thermal throttle constantly, this will ruin your FPS for long bouts of gaming and make your GPU thermal throttle also.
If you're temps are always 93oC+, your paste will dry faster and reduce longevity of your CPU.
I recommend you reinstall MSI-test graphics driver first and check the laptop's performance.
1. You can download them from the MSI website and refer to the FAQ to perform a reinstallation.
[How To] Intel graphics driver Clean Install & Update - https://www.msi.com/faq/notebook-3267
[How To] NVIDIA graphics driver Clean Install & Update - https://www.msi.com/faq/notebook-2110
2. Check the laptop's performance.
You can refer to the official FAQ (Page 8 - Check the graphics performance)
FAQ - https://www.msi.com/faq/faq-2424
3. Compare the result from Notebookcheck.
NotebookCheck - https://www.notebookcheck.net/MSI-G...ew-GeForce-RTX-3060-on-a-Budget.526258.0.html
