GF65 wifi issue
sytrzh152802d2
hello i am having an extremely annoying wifi issue, my wi-fi goes from 50mbps down to 5mbps and even lower in an instant, i can sometimes manage to maintain my 50 mbps speed for a day but then i am plagued with the terrible connection for the same amount of time, i have tried changing my properties for my intel wifi card and have updated the drivers. i have tried a wifi adapter which gives me normal and consistant speeds however i cannot keep it in as i do not have enough usb slots, if anyone could help that would be great. (using intel(r) wifi 6 ax201 160mhz)
sytrzh152802d2
the only way the issue fixes is when i reset my router but i cant constantly do this, if anyone knows anyway they could help it i would really appreciate it
drek4
PRIVATE FIRST CLASS
If you have to constantly reset your router, then maybe your router is the culprit.
How old is your router? If more than 4-5 years, replace it.
Does it run hot? Put a fan next to it or a laptop cooler under it.
Have you updated the firmware? Update it.
What type of router is it, G, N, AC or AX? If G or N, replace it, if AC or AX update firmware.
Can your router be scheduled to auto reset? Plug it in a timer that shuts off at 04:00 AM and back on at 04:05 AM every morning.
RaiderGamer
Active member
MAJOR GENERAL
double reception and speed
plug and play with windows 10
works on or off dock
2g and 5g
nysmeee155102da
Active member
Which laptop (RTX 20 or 30 series graphics)?
Although you've tried to reinstall the drivers, try follow this guide to do the clean installation again.
What you're doing when wi-fi goes from 50mbps down to 5mbps?
sytrzh152802d2
30 series and i could be doing anything it is completely random, like the past few days its been fine but today it dropped again, and it seems the only way to fix it for a few days it to restart router.
