GF66 11ug
andy2504115b302e4
hi all
can anyone tell me how to fit a wd blue 2.5 2TB SSD, I opened the back to fit it and to my surprise, there's a large battery in the way of the slots. is there a way to upgrade my memory without the 2.5
badboy2k
no you cant put a 2.5 inch SSD in the machine as like you see the battery is in the way the only option you have is to install a 2nd M.2 Drive as you do have a open slot for one and will be a 2280 PCI-E NVME Drive
Saeba Ryo
If you wanna upgrade the memory, the slots are not under the battery.
The location should be the top right corner of the picture and the slots are covered by the plastic shielding.
hi all
can anyone tell me how to fit a wd blue 2.5 2TB SSD, I opened the back to fit it and to my surprise, there's a large battery in the way of the slots. is there a way to upgrade my memory without the 2.5 View attachment 166611
