GL65 Leopard Fan Sound Problem
Hi everyone.
  • I've been having a fan voice problem lately. I don't know what triggered it, but the fan noise has started to increase unbearably. His fans are running at high speed, as if he is working in the ultra performance mode in dragon center. I tried the following steps to fix it, but it still hasn't changed.
  • I deleted Dragon center and reinstalled it.
  • I've tried older versions.
  • I downloaded silent options and tried silent mode, it didn't happen.
    I saw a post like setting the fan speed through the BIOS, I was going to try it, but I couldn't find it.
    I formatted it so that if it's a driver, maybe it will be solved, it didn't happen either.
  • I am desperate from this point on, I am open to any suggestions :(
  • Thank you
mimimaomao
The fan will launch when it detects a high temperature, no matter if you uninstall Dragon Center.
On the contrary, we can set the fan with the workload you want in Dragon Center.
You could set the user scenario to extreme performance and click the gear, then you can set the fan usage according to the temperature as you preferred.
Thank you for the answer, but the situation on my computer is a little different. As soon as the computer turns on, it starts working loudly. The user setting from dragon center also didn't make a difference. Yesterday it was quiet for a few hours, but now it is working out loud again.
drek4
Active member
PRIVATE FIRST CLASS
Try putting the maximum CPU power to 99% in power settings, this will keep TURBO from kicking in.
If the fan is less noisy after this, then it's your CPU that is going on TURBO that is ramping up your fan, not a software issue.
I prefer using TS, that way I can tailor my CPU as I want, according to what I do, gaming, internet or when on battery.
Greetings again. There has been no fan sound problem for a while, but it started again for no reason. In the image below, you see the laptop temperature and rpm values. Still, the fan sounds crazy. There was no solution to bring the CPU value to 99%. The user scenerio recommendations also did not work. I am open to your help and suggestions.
Thanks.
