GL66 power brick
fiorucci92158402e2
I need a 2nd power brick for my GL66. It’s the model that ends in a K with the 3070. I ordered one (180w) that said it works but the plug into the laptop it too big. I tried to see if my GS63 stealth plug fit and it does not. Amazon is no help, and msi doesn’t list any info on the correct plug size. It looks to need to be just a tiny bit smaller than the GS63 plug. Any ideas? Thanks!
fiorucci92158402e2
The specs say nothing about the plug size. There is absolutely no information on the power brick other than the wattage. Not the plug that goes into the wall, the end that goes into the laptop.
Usually, you can find your AC adapter by search on Internet, find the right watt adapter then it works.
What's your product name? I can check it for you.
I can not find your product on MSI. It is so weird.
Maybe you should ask the service center and tell them about this.
drek4
Active member
PRIVATE FIRST CLASS
