GL75 Boot up hang help
cysee12cd02b0
GL75 9sdk purchases 01/2020
The past several days my laptop hung midway surfing. Had to force restart with power button.
On the 3rd time, I cannot get past the msi screen. The circle thing will move and hang.
I tried to create media creation tool and restart from USB and that hang too.
Can anybody help ?
cysee12cd02b0
Did you manage to resolve it ?
Called the msi help desk and did bios check, ram check and power reset (pin hole back of laptop) with no success.
Next is to check the ram.
andreimitre15bf02e8
Still on it. My issue is I tried to install dual os Linux windows but the bios did not open so I could not set up the booting choice and ever since two days ago my laptop doesn’t boot windows anymore
RaiderGamer
MAJOR GENERAL
update bios reset bios
update ec reset ec
test hard drive
test ram
remake windows usb
bring up boot menu and boot from windows usb
RaiderGamer
MAJOR GENERAL
Any guidance on updating bios / reset bios? I can only access the bios setup.
i dont konw if u can update bios from within bios
some things u can do that
put bios file on usb and try updating from whithin if i allows
