GM50 Flicker - Assassins Creed Odyssey MSI Mystic Light
conbarge
Hi All,
No sure if anyone else has come across this, but I seem to get RGB flicker (every 3 time a second) on my new GM50 mouse, when playing Assassin's Creed Odyssey with the MSI Mystic Light integration. My GK50 keyborad is working fine with Assassin's Creed itself (although the RGB profile doesn't return to normal when I exit, but I have a support ticket open with MSI on this).
Has anyone else come across this? It also seems to happen if when using the 'All Sync' option in the Mystic Light, and trying some of the RGB options in there. When I do this, I also get flickering (but I do not if I set RGB options on the mouse, as a stand along).
Any help would be great.
Thanks,
Con
fatedust
FIRST LIEUTENANT
Hi conbarge,
What version of Mystic Light? And what's your motherboard?
conbarge
Hi fatedust,
I installed 2.0.54 yesterday and tested, and I'm still having the same issue. My motherboard is non-MSI - its a ASUS Hero VIII.
fatedust
FIRST LIEUTENANT
Hi conbarge,
Have you tried to go to Live Update in Dragon Center and click Advance and then Scan, is there any newer version of firmware for your mouse?
Btw, you can see the current firmware version of your mouse and Mystic Light version under System Info in Dragon Center.
conbarge
Hi fatedust,
Yes, I did that initially, no new updates available. Here is my current firmware list:
Module Information
Device FW Update(GK50 LP)     1.01.18
Device FW Update(GM50)        136
Base Module                   1.0.0.39
Gaming Gear                   1.0.0.07
Engine                        1.0.0.52
FWRescue                      1.0.0.07
My Device                     1.0.0.05
Mystic Light                  1.0.0.70
Nahimic                       1.0.0.06
SDK                           1.0.0.46
Support                       1.0.0.44
Voice Control                 1.0.0.09
Thanks! :)
fatedust
FIRST LIEUTENANT
If you are already on the latest version, then let's wait for MSI to release new firmware update on your mouse.
Meanwhile, the workaround now to avoid this flicker issue seems to set the RGB effects on the mouse along not by All Sync. :undecided:
conbarge
The All Sync is just an example outside of Odyssey; within Odyssey, irrespective of the settings outside, it will flicker (while using the MSI Mystic Light integration).
fatedust
FIRST LIEUTENANT
This proves again there is something wrong on the firmware of your mouse.
