GOP / UEFI Vbios requests - Read Here First
Status
Not open for further replies.
xmad
Active member
GENERAL OF THE ARMY
Latest Info:
The moderators here on the forums no longer can provide any support regarding VBIOS's.
If you want an updated VBIOS.
If you want the VBIOS that shipped with your card.
Or if you want ANYTHING at all related to the VBIOS, you'll need to contact MSI directly.
See : >>How to contact MSI.<<
Old archived:
If you are looking for a UEFI / GOP Vbios for your video card here are a few things we need and there are a few things you need to know.
1.) Vbios versions vary with-in models. This is due to different variations and improvements made in time. In order for us to be able to get you the right VBIOS. We need your serial number. The serial number can be found on a sticker on the bottom of your card or on the box in which it came.
2.) Don't use a vbios provided to another users. Just because you have the same model, doesn't mean you need the same vbios. While flashing the wrong vbios is in most cases (=not all) recoverable, it is still more work. It is fine to post in that thread with your serial number asking if you can use that VBIOS. :nono:
3.) We will usually need to check your current vbios. We can check your vbios in one of three ways.
   A.) Download and run GPU-Z:
https://www.techpowerup.com/download/techpowerup-gpu-z/
then check under "Advanced" tab, then under "BIOS scroll":
    B.) Upload a copy of your current vbios somewhere and give us a link. You can save a copy of your vbios using >>GPU-Z<<.
[attachthumb=1]
    C.) For a Nvidia card you can also just use NVFLASH >>Download NVFLASH for windows<<
Syntax:
nvflash /v >rep.txt [ENTER]
This will copy all of the information we need into a txt file you will fine in the folder in which you placed nvflash.
    C.) For an AMD card you can also use ATIWinflash and save the vbios: >>Download ATIFLASH (Winflash included)<</
4.) Be aware that gpu-z screenshots or what gpu-z reads out as bios version are NOT of any use for identifying the required vbios version. While it doesn't hurt to add those when S/N and an actual copy of the vbios are also supplied simply just adding screenshots or version readouts will not get you any further and us having to ask for the required informations.
[attachthumb=2] [attachthumb=3]
Status
