gp63 leopard 8RD (not RE)
carol_sama
I want to buy this notebook but I cant find the model panel. Does anyone knows which is it? I am a graphic designer that likes to game so a proper screen is a must!
Thank you
whitecat8890
SECOND LIEUTENANT
I am not sure and won't guarantee.
I think the panel is supposed to be "120Hz, 3ms, IPS-level"
But the panel must vary from product to product. You should just ask the salesperson you met.
carol_sama
Thank you for taking your time to answer me!
I actually emailed MSI and the answer that I got was a google search that I ve done it myself. Very lazy response from the manufacturer and didnt contain the answer that I need it. I think I am going to have to find a owner of this model and perhaps ask that person.
Cheers!
Amaella
Active member
MAJOR
Hello, it depends on which exact model it is (even gp63 8rd's can vary based on the numbers behind it). The only one who really knows is the reseller so you will have to see which variants are available in your country and contact the seller. E.g. my laptop is gt75 8rg-016NL (the last number+letter combo reflects the specific configuration of ssds/ram/screen in your case and country).
So yeah, there can be gp63 8rd's with 60Hz display, but it can also have 120Hz screen....The 120Hz is TN but seems to have better accuracy while the 60Hz is IPS but overall seems to be low quality from what I heard.
Just as another user was shocked his ge series came with 60Hz 4k display while expecting a 120Hz - really only the seller knows what they sell (well, at least they should).
