GPU Bracket Position - Angled
eromasterster
Hello guys
I just reseated my GPU bracket under my graphics card after noticing that the center pad wasn't in contact with the card and only the pad on the edge of the bracket was. Which in case, made it fall off the bracket slightly. I was able to arrange back in place thanks to the glue that hold the pads.
So I adjusted it now, where the center pad is touching the bottom of card helping to hold it up preventing the sagging. It actually made the sagging much less noticeable as before. Also, the edge padding isn't in much contact with the edge of the card this time, preventing from detaching it from the bracket like before.
Now esthetically, although the card itself its very even with the rest of the rig, the bracket itself is quite angled as you can see in the photo. Link below:
My question is: is it OK to leave it like that? Or I should bother it adjusting it again?
It doesn't really bother me the way it looks as long as you guys can confirm it is actually ok the way it is holding that GPU.
Please let me know. I really appreciate it.
Thank you in advance.
Administrator
What GPU is this?
Try adjust and re-seat the bracket, ensure good contact in top right corner.
eromasterster
What GPU is this?
That is a MSI RTX 2070 Super Gaming X Twin Frozr 7. I did reseat the bracket, now the top right corner is fully in contact with the cards shroud, as well as the middle pad is supporting it a bit as well.
