W wpicke159302df New member Joined May 19, 2023 Messages 1 May 19, 2023 #1 Has anyone else experienced the situation were GPU speed is not displayed in the MSI Center? If so, how did you address / fix it? THANKS!
badboy2k Well-known member Global Moderator Joined Feb 11, 2012 Messages 13,355 May 19, 2023 #2 wpicke159302df said: Has anyone else experienced the situation were GPU speed is not displayed in the MSI Center? If so, how did you address / fix it? THANKS! View attachment 172919 Click to expand... what GPU do you even have as we cant Read minds here?
A aksoyozca150e02d4 New member Joined Sep 29, 2020 Messages 19 May 19, 2023 #3 Don't worry very normal if it is not under load it will show as 0RPM try to run graphic demanding programs or games and check again it should kick on the fan again.....
