Hi, No idea for it, becasue RTX 40 series graphic cards are not listed in recommend.
https://www.msi.com/Desktop/Trident-3-8th/support#recommend
Shouldn't mean much. Of course MSI are not testing every new card that comes out with each of their older systems. So you will only find older hardware there. But a GPU should be universally compatible (even though on this system, it would be limited to PCIe 3.0 x8 speeds).
But Trident 3 is sold as upgradeable then advertising and descriptions are misleading. I will never buy Trident series and equivalent anymore.
You did connect the 8-pin PCIe power, right?
With those complete pre-built systems, especially from a brand like MSI, they are more convenient, but they have a few downsides that you only discover later. But actually, you can see immediately that this is not very upgradable at all:
As with a lot of compact pre-built PCs, you cannot upgrade the motherboard at all, because it's a unique form factor, it's much more like a notebook/laptop in that regard. The components in such PCs are tailor-made. It's always better to buy something that isn't such a custom design, or to build it all yourself. Then you can use a standard ATX or Micro-ATX case and choose the ideal components for everything, plus you'd actually have the chance to upgrade each part later. Furthermore, on those pre-built PCs, they don't tend to put a lot of effort into developing the BIOS, and they sometimes severely castrate the BIOS options.
So when you buy a system the size of a small gaming console with an external PSU "brick" and believe what they are saying about upgradability, you are just believing their marketing. Apart from a notebook, there's not many worse possibilities i can think of for upgrading them later. The more like a normal full-size PC it looks, the better for upgrading.
Ultimately, it could very well be an odd compatibility issue here, maybe also due to the weird way the GPU is connected to the board, it looks like some kind of riser cable situation or similar, perhaps? But with the kind of hardware that's in there, it's getting a bit long in the tooth. I would try to sell this entire system while it's still worth something, and get new PC altogether.
You could then get another pre-built PC of a proper size, but even then, there can sometimes be mismatched hardware as can be seen
here for example. Furthermore, read
here. Plus you can watch
this video for some common mistakes or downside of pre-built PCs. But if you choose a completely configurable PC and make good selections (and let the forum like here help you perhaps), then it could be a new PC that would be a breeze to upgrade later.
