Graphics Output Protocol
hankers158a02e2
Płyta MSI B460M Pro-VDH Wifi procesor i5 10400F, karta Radeon RX550 Jak w tytule, przy próbie zmiany w biosie na UEFI za każdym razem wywala mnie na CSM
hankers158a02e2
MSI B460M Pro-VDH Wifi i5 10400F processor, Radeon RX550 card As in the title, when I try to change the bios to UEFI it crashes me on CSM every time Attachments
Nichrome
Friday? Deploy to prod!
Check with your GPU manufacturer for GOP vBIOS.
Pro
Yes. The older cards have a VBIOS (Video BIOS), which works well together with an old mainboard BIOS (or a newer mainboard BIOS set to CSM/Legacy mode) and an old OS such as Windows 7.
But nowadays, with the BIOS set to UEFI mode, it requires the graphics card to have a GOP (Graphics Output Protocol driver). Since only Windows 7 (or an old Win10 installation that was done in CSM/Legacy mode) need a VBIOS, but a new installation will use UEFI + GOP anyway, the old VBIOS is simply not supported in UEFI mode.
First, update your mainboard BIOS to the newest one: https://www.msi.com/Motherboard/support/B460M-PRO-VDH-WIFI
If that doesn't help, then to get rid of that message, you need to update the graphics card's BIOS. You can look here for an appropriate one,
https://www.techpowerup.com/vgabios...el=RX+550&interface=&memType=&memSize=&since=
First do additional research, i am sure people had that problem before.
If none of the above solves it, you have to set the BIOS to CSM/Legacy mode. But that means Windows 11 won't be happy.
