Grinding and clicking noise
aatif120158002da
Hi.
Please help with the below issue I use my laptop for work and gaming but mainly work and I’m freaking out.
When I turned my laptop on, it started making a really loud ‘grinding/wiring’ noise that lasted a few seconds and repeated a few times. Thereafter I logged in and my laptop was then making a clicking sound (approx 3 clicks) and continuously repeating with a few seconds intervals. Take note that my laptop seemed fine, didn’t lagged at all and was functioning as normal. I then opened up task manager to see the status my hdd and after like 30 seconds the grinding sound reappeared but in a much more aggressive and non stop way. I then proceeded to shut off the laptop as I was scared of causing further damage. I did record a voice note of the sounds but I can’t seem to figure how to upload the voice note on to this forum.
Please help :(
dvair
Active member
SECOND LIEUTENANT
Possibly a fan hitting against something.
aatif120158002da
My laptop is out of warranty, I do hold bcomsci degree so I am familiar with opening pcs but not laptops….
dvair
Active member
SECOND LIEUTENANT
Out of warranty, I would take out the screws on the bottom and carefully open it up to see if it is the fan and if something rubbing against it.
Its a fan shaft that died out due to high temperatures. A very common occurence in msi laptops. You have two options. 1 - buy a new fan. 2 - take out the fan and clean the shaft with compressed air. Put some machine oil into the fan's shaft - a very tiny drop.
Both solutions make your fan last for a long time.
