Grphics card riser cable
willistv68
PRIVATE FIRST CLASS
Just bought a sekira 500x case. I want to mount my GPU vertically. What Riser Cable is compatible with the case? And do I also need a separate bracket to mount the cable to, or will it mount directly to the case?
It doesn't matter for the case what riser cable you use. Simply test-mount the graphics card and check what length you need to reach the slot of your mainboard.. The riser cable is then just a cable. It connects the graphics card and the slot, there is no different mounting needed.
carte45bc067e
I have a msi 2080ti trio im trying to vertical mount in my Sekira 500x and it isn't fitting. I have the riser cable but the card is not sitting riggt at the bottom of the case. I can see where there should be aome kind of sipport below the card but i dont have anything to put there
Please open your own thread with photos of the situation.
