GS63VR Stealth Pro, Keyboard LED Control?????
crazyhamsales
Can anyone tell me how to control the color of the backlit keyboard on this GS63VR Stealth Pro???
I contacted support through the online chat, gave them my serial number, they said yep its a GS63VR Stealth Pro 7th Gen GTX1060 and that i should go to the downloads page, they even linked me to it in the support chat, told me to go to utility and download the Steel Series Engine, it has version 3.11.2 on there.  I downloaded it and ran it and it says no Steel Series devices are connected so i still can't control the keyboard.
I went into device manager and it shows the keyboard as a standard ps2 keyboard??  The support person said the SSE would update the driver for it but it didnt do anything.  Then they said to install the Dragon Control Center, so i did that as well, and that i should use the LED tab in that, there is no LED tab in that software, no mention of the lighting or keyboard or anything.
So after a couple hours on tech support chat and a couple days of google searching i am here after exhausting all my options.  Its stuck in annoying red, and i want to change the color on it.  It used to work but the led control disappeared from the Dragon Control Center after reinstalling windows and putting in the version i was told to.  I can't find an older version to try but i am guessing the version on the support page for my laptop is not correct and i need an older version which is nonexistent online.
Help??
1950135645
CORPORAL
首先,键盘应该是背光的,其次,它具有设置背光颜色的功能。
   通常,fn +快捷键Fn + Esc用于调整背光颜色。不同品牌和制造商生产的键盘快捷方式可能不相同。有关详细信息,请参阅说明。
  对于终结者,调整灯光的方式:
   首次连接键盘时,默认设置为打开背光状态。按住fn功能键,并且每次轻击照明键,您都可以降低亮度,直到关闭背光。再次按住fn键,然后单击照明灯键以打开照明灯。
Help??
Crazydonkey
SECOND LIEUTENANT
Do you have the same model?
Update the latest DC and also go to MSI website utility page to check whether your laptop support SteelSeries engine.
If yes, download it and change the backlit though SSE.
