- Aug 5, 2016
GS72 stealth pro
Win10 home
Realtec 6.0.1.7885.
Nvidia 10.18.13.5435 (I heard this is also somehow messing with audio)
I use "line in" for my guitar and want to hear it in a headphone connected to the headphone jack.
When connecting the headphone, a box pops up asking what I connected... I answer HiFi headphone.
I set the headphone as default playback device in Windows.
After that the audio from various programs gets correctly played through the headphones, but the signal coming from the line in still goes to the on board speakers.
I am used from other notebooks that once you connect a headphone, the onboard speakers are quiet and everything comes on the headphones.
Interestingly when using "guitar rig" (a SW signal processor for guitar), it uses the line in signal as input,
but it's output also comes on the onboard speakers but still the direct signal from the line in is also there.
So it somehow appears the line in signal gets routed directly to the onboard speakers, but still somehow parallel gets used as a recording device.
Would appreciate any help on that, since I already wasted quite a few hours tinkering with it without success.
Cheers
Willy
350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum, 350 words minimum
Win10 home
Realtec 6.0.1.7885.
Cheers
Willy
