- Apr 15, 2017
Specs: i7 7820HK / GTX 1080 / 32g RAM
Hello, I was wondering if the temperatures I'm getting are considered normal, I thought my temperatures would be lower than what I am getting since MSI is known for their thermal control. When I play Overwatch or For Honor I am reaching anywhere from 75 degrees which is fine but then I can even go to the 80-82 degrees. Is this normal, or should I be floating around a lower temperature? How would I test my CPU / GPU under a max load and see the temperatures? What temperature should I be expecting under a max load?
Thanks
Thanks
