GT780R and issues with cpu-z and Core temp
shokyoya
Was wondering if anyone else seem to be having issues using these, atm they dont always seem to report the chip, and show only 2 cores, 4 threads instead of what it is 4 cores 8 threads and only showing 2 core temps  1 and 2 cores 3 and 4 dont display.  windows still shows 8 processors in device manager 4 real and 4 virtual etc... and ive run intel processor id and didnt show any errors, im wondering if anyonoe knows if there is only 2 sensors on the i7 chip or do u think that possibly mine have died or something? currently was unaware of it till i used those and found them not iding correctly, aida64 Extreme edition is same way cept it shows 4 cores, but only sensors for  1 and 2 (64bit everest basically) if anyone with a GT780R-012US can say they are having trouble seeing 4 temps or 2 temps improper iding of the chip, my troubles would be eased to they just need to update for better compatability
ok figured out the problem i had re enable core parking and get rid of windows booting with 4 cores , appearently they cant recognize the mobile processor otherwise which is odd but oh well so nothings wrong got cpu-z and core temp to identify correctly once i reset those options back to default ;p thank god thought maybe i burned out the cpu lol
