GT780R Power Adapter Source
https://shop.msicomputer.com/default.aspx
Check the part number on your current adapter, its probably the same as for another notebook.
It's  150W. 19.5V and 7.7A.
I notice some of the Dells have the same specs, not sure about the tips.
Look for 150W units and check volts and amps, then check tiips. Some stock a range of tips. A 12V car charger I bought recently had 10 tips included.
Note that some generic units are only 90W
This one appears to be the same one from ASUS: http://us.estore.asus.com/index.php?l=product_detail&p=3561
I recieved the 150 watt adapter from Asus today. It seems to work fine. I have the power draw maxed out right now, charging the battery and running BOINC to max out all the cores and the gpu. Every seems to be working fine but as always YMMV.
